Home > Maintenance & Modifications > Your 5 Top Modifications |
[quote="bpman"][quote="The Musketeer"]
BPman, the Entreq fuel cooler guard, did you buy the version with, or without stabilizer? Could you install it yourself easily, or is the a job for Autobritt here? Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
13th Feb 2012 9:30pm |
Ericvv ... parrot ice ... Entreq fuel cooler guard - stabiliser means anti-roll bar - yes I bought with stabiliser, easy to fit but you need a rivnut tool and dinitrol to do a good job. PM me and I will send you photos and info. bp |
13th Feb 2012 9:46pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
This is Parrot ICE.....
13th Feb 2012 9:54pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
13th Feb 2012 9:55pm |
to get the rear wiper to run delayed - I used the front wiper relay when I replaced it with the programmable variable relay for the front wipers ... does that make sense ? |
22nd Feb 2012 9:44pm |
Ravers Member Since: 22 Feb 2012 Location: Germany Posts: 19 |
Ahhh yes. Thought about doing it for ages, was it a complicated job? I'm not into ripping the new defender to bits just yet. Thanks Ravers |
22nd Feb 2012 9:50pm |
to install the front wiper delay relay is easy, but the rear relay needs a few wire changes, do a search on the forum for more details. dgardel is the wiring king ! |
22nd Feb 2012 11:18pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
cheers BP, i was a bit slow in responding to that query (and you have answered it better than i would of).
23rd Feb 2012 11:17am |
For normal intermittence (using the OLD front Land Rover relay) VERY EASY MOD!!!! Have you a standard/original Land Rover wiper ECU in your hand? The green-white cable of position 6 of the base must be put on position 1 Test it.............................. ..............job done FOR A MORE REFINED SOLUTION, Thank you to BarneyRubble for adding the VW variable timer to the rear wiper download here the BarneyRubble pdf Works like the front - press the switch, let it wipe, switch it off, wait until you want it to wipe again, switch it on, and leave it - the wipers operate on intermit at the time you left between switching off and back on again. Click image to enlarge Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 23rd Feb 2012 11:26am. Edited 1 time in total |
23rd Feb 2012 11:21am |
It's an interesting mod (just up my street) but I hardly ever use the rear wiper anyway - not much point, since the security grill makes the window redundant Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
Modded my previous post with TWO solution............. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
23rd Feb 2012 11:28am |
Why use the extra black wire? Is the green/white one too short or can't you fish the connector out of the block? Sorry if that's a stupid question Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
23rd Feb 2012 11:36am |
Moving the cable on the new position you need to change the pin (it is smaller).
I build the black one for do not modify the original harness Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
23rd Feb 2012 11:56am |
Aha
Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
23rd Feb 2012 12:03pm |
