Home > Technical > BP Ultimate!
Page 1 of 4 1234>
Zagato
BP Ultimate!
I am using BP Ultimate as I generally do stop start runs and Ultimate is meant to have a cleaning agent in it that may stop it coking up so much, is that right? Doesn't this also go against the theory of putting in two stroke oil for lubrication Confused
I don't put in 2 stroke oil as I get my knickers in a twist if anything is done out of the ordinary Shocked Laughing
Post #124341 16th Feb 2012 2:52am
ericvv
Re: BP Ultimate!
BP ultimate especially is more expensive than regular diesel, contains more additives of course (do we need them?) and believe also a higher percentage of bio-diesel.
I have read several tests which tried to compare fuel consumption of same cars with regular diesel and with these more expensive Ultimate, etc.
Conclusion of each test...... A waste of money, use the cheapest available diesel is the advise.
Now, with our Defenders Land Rover are saying clearly that the engine is adjusted so that the car can run on poorer quality fuels (often higher sulfur content) which often are the only ones available in Africa or in the East.
So with us here in West Europe having probably avail to the better qualities anyway, why pay for those premium fuels.
In my particular case, 90% of the time, at home, I use regular French supermarket chain diesel, and the car has been running fine on it for 50k km. The times that I travel and use diesel of premium brands (never their Ultimate stuff though) I have not noticed anything different.... That engine makes the same sound, runs the same,..... so will stick to the supermarket brands. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #124344 16th Feb 2012 5:38am
Surrey Rover
If I owned an Enzo I might consider using BP's Ultimate or whatever is the equivalent for petrol. On a Defender, no way.
I have never had a problem sticking to "normal diesel" and never had a problem because I don't stick two stroke in either. Fill it up with whatever diesel is at hand, drive it and enjoy it. Don't put petrol in it though, I tried that but it didn't like it! Nick
2.2 110 Tipper
Post #124351 16th Feb 2012 7:11am
Although I may be a little biased, I would recommend BP Ultimate but only every 4th tank AND buy it from a garage that sells lots of Ultimate. A mate from work had problems with his VW directly after buying an "old" batch of ultimate.
It's got great cleaning chemicals in it and that's exactly why you don't need it every tank
I also add mineral 2 stroke, but every other tank...
Post #124356 16th Feb 2012 7:18am
Surrey Rover
BPMan, is there scientific data to backup the claims of these ultimate fuels. Not marketing bumfph but real data from cars driving about. I am not questioning your comments or wanting to get in a ding dong but over 100K+ mileage experience in Defenders tells me these cleansing agents are just not needed.
My experience aside, think of how many millions of miles have been driven by diesels around the civilised western world without the need for Ultimate fuel, and now it's out everyone is recommending it. I can't get my head around it personally and see it up there with snake oil and carbon fibre parts for "lightening the load" Nick
2.2 110 Tipper
Post #124359 16th Feb 2012 7:26am
probably somewhere on the BP web site there will be some blurb, might be worth googling it. As well as my land rovers, I also drive a 1.6 tdci (ford) it has a MPG guage, regular diesel I get 52-54 mpg, with Ultimate I get 56-59mpg .. so there is something in it.. also, the way diesel is blended now is different because they add a percentage of bio. Try it and see if it makes a difference to your motor. Sorry I can't be more technical help
try this http://www.bp.com/countryjump.do?categoryI...Id=7048575
Post #124365 16th Feb 2012 7:42am
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Might be a dumb question but how do you know which garages are selling more of the stuff versus it sitting in the tanks?
Post #124429 16th Feb 2012 1:31pm
Lorryman100
I use Ultimate fuel nearly every tank now, it would be every tank but the garage I use, frequently runs out of the stuff. There are benefits from using any high cetane rated fuel simply for the quick ignition and smooth burn. Low cetane fuels are slow to ignite and burn to quickly which results in reduced performance, excessive engine clatter and vibration. Ultimate and v power both have a high cetane rating and both fuels include anti foaming agents, anti corrosion inhibitors and injector cleaning agents which stop the build up of carbon on the injector nozzles.
And for me, the Puma runs better on the BP stuff compared to Shell and the others. If I have to use supermarket fuel then I add 2SO simply for the extra lubrication it supplies to the fuel system, something the ultimate seems to do as standard. And every six months I also add Forte diesel treatment to the tank as it is a more concentrated cleaning agent. Thumbs Up
Post #124456 16th Feb 2012 3:41pm
pannawonica
Australia
BP ultimate is not available here, I use a little 2SO mineral. Without any doubt it makes the engine much quieter and smoother. I cannot comment on economy, that was n't the reason for Defender ownership. Very Happy
Post #124636 16th Feb 2012 11:46pm
Lorryman100
The reason for adding 2SO to the fuel in the first place was to replace the lubricant that was naturally present in diesel fuel until the newer low sulphur fuels appeared on the market. The main lubricant in the older fuels was sulphur. Thumbs Up
Post #124639 16th Feb 2012 11:51pm
pannawonica
Australia
[quote="Lorryman100"]The reason for adding 2SO to the fuel in the first place was to replace the lubricant that was naturally present in diesel fuel until the newer low sulphur fuels appeared on the market. The main lubricant in the older fuels was sulphur. Thumbs Up[/quote]
Yes this is quite correct Thumbs Up We here are now down to @ 50ppm sulphur. I do appreciate the added refinement that the engine seems to display. I assume the cetane level is increased. Normally I fill the tank with BP, the other vendors advertise Bio is added which I avoid.
Post #124641 17th Feb 2012 1:11am
wslr
Yep, I notice the BP Ultimate better over the Shell. I can't get it easily around here so I get the standard Texaco diesel and add a bottle of Barnes or Wynns fuel treatment every fill. Much quieter TDCI and it increases the cetane index.
Post #124709 17th Feb 2012 12:05pm
BigRuss
Well I don't really care which one I put in because I pay the same price for both but less that you Lot Mr. Green Russell
2011MY 110 XS USW Black
Post #124885 18th Feb 2012 2:02am
hey Russell - get us some cheap diesel Whistle
Post #124893 18th Feb 2012 6:36am
Surrey Rover
Company fuel card?
Those were the days, filling up the V8 without a care in the world! RIP my fuel card Nick
2.2 110 Tipper
Post #124902 18th Feb 2012 7:40am
Page 1 of 4 1234>
