Home > Maintenance & Modifications > Your 5 Top Modifications
Page 2 of 9 <123456789>
mine are:
1. additional security measures
2. rustproofing
3. crystals + h4 PIAAs
4. parrot ICE
5. entreq FCG
Post #123579 13th Feb 2012 9:06am
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Waxoyl
Adjustable towbar
rear bumperettes
blue tooth stereo
Roof bars 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #123581 13th Feb 2012 9:11am
MartinK
ericvv wrote:
4. A good set of front fog lights, Hella in my case, which in combo with my SVX front lights leave nothing further to be desired really. (Except mayby the JWSpeaker LED's once I get the Swiss authorities to approve them Big Cry
As you're in Switzerland, I guess you can use these! Illegal to use them in UK unless the visibility is less than 100 metres - which is of course about once every 5 years Confused Confused Round here, people with front fogs on (when it's not foggy) get stopped - the Police use this as a reason to pull people over for a spot check Thumbs Up
I guess it's either legal in Switzerland, or you get a lot of fog??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #123584 13th Feb 2012 9:46am
One of my favourite targets of vitriolic hatred is the people who use front foglights when it isn't foggy, and I totally support any initiative by the Police to pull over people who drive with them on when it's illegal.
Having said that, there is a strong argument for fitting front fogs on a Defender, since the headlights are so high up, and, especially if you have upgraded the headlights, backscatter in fog is a real problem.
If you fit a good quality fog-beam light above the bumper, it will be low enough to work well as a fog light but high enough legally to not be a fog light, and therefore, provided it is adjusted so that it cannot dazzle oncoming drivers (and a properly adjusted fog light - in dry conditions at least - won't) can be used at any time.
A lamp becomes a fog light in the eyes of the law by virtue of the fact that its centre is 600mm or less from the road surface. Anything greater than 600mm is not considered a fog light and is not subject to the fog, falling snow, or seriously reduced visibility restriction.
On a related note, why do people wire foglights up so that they work WITH headlamps? If you need a fog light ON, you need headlamps OFF. A lot of the morons who drive with them on all the time could be stopped if type-approval required that foglamp activation disabled the headlights.
And please, don't get me started on rear fog lights, the most useless and dangerous idea since the man with the red flag was done away with!
Post #123586 13th Feb 2012 10:25am
JSG
As mine is an XS it came with heated seats, heated screen, tow bar etc so in terms of things I've added;
1, Protection - Waxoyl and rubber mats inside
2, Security - Under cubby safe and pedal locks / etc
3, Extra 12v sockets for fridge and chargers
4, Variable wiper relay
5, Storage - Glove box, Roof bars. John
2011 Tdci 110 CSW XS
Post #123595 13th Feb 2012 11:25am
Grockle
Rust proof
Sound proofing
Head light upgrade
Driving lamps
Hardwire tom tom lead 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #123600 13th Feb 2012 12:17pm
farmer giles
top 5 for my family life puma 110 are:
1. sub, amp, mids and tweeters + ipod head unit stereo
2. rear nas step
3. variable wiper relay
4. rear door power strut
5. spotlights to "encourage" oncoming drivers to dip their lights
top 5 for my single life td5 90
1. sub, amp, mids and tweeters +ipod head unit
2. J E Engineering remap and intercooler
3. twisted performance sports exhaust
4. koni suspension 1" drop
5. j e engineering spotlights in grille
Post #123601 13th Feb 2012 12:24pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
1. Undersealing the chassis
2. Blue tooth phone kit
3. Securtiy cubby box
4. Sun visor
5. BFG's
Post #123604 13th Feb 2012 12:37pm
ericvv
Not a lot of fog, but fog lights can be used legally when there is fog Thumbs Up or in other cases of seriously reduced visibility, i.e. also with heavy rain, snowfall, etc.
A lot of people here are using their front fog lights in combination with their main beam, but don't think police are doing much about it.
I personally think if front fog lights are good quality and properly installed, AND ARE ADJUSTED SO THAT THEY DO NOT DAZZLE ONCOMING TRAFFIC, there is nothing wrong with using them.
Too many after market fog lights are poorly installed, poorly adjusted. In that case police would have a point in stopping you. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #123619 13th Feb 2012 1:43pm
ericvv
Post #123664 13th Feb 2012 4:39pm
The big problem with using fog lights in the rain is the glare they cause off the wet road surface.
I'm pretty sure that on modern cars fog lights are wired to switch off if main beam is selected. Not necessarily true for aftermarket installations though, I suppose. Darren
Post #123678 13th Feb 2012 5:46pm
ericvv
Correct wiring for front fog lights, and how mine are wired by the local LR dealer, so that must be in line with EU and Swiss law (which are the same by the way):
You can switch them on together with the parking lights and also with the dipped beam.
They automatically switch off with the high beam turned on.
I don't think that the last one there is actually mandatory. For instance my wife's VW has original ex factory HID lights, but her front fog lights do not switch off automatically with high beam engaged. You never actually own a Defender. You merely look after it for the next generation.
Post #123680 13th Feb 2012 5:55pm
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
bpman wrote:
mine are:
4. parrot ICE
5. entreq FCG
I have no idea what they are... I assume 3 is something to do with lights? Shocked Good things come to the wild and free
Post #123702 13th Feb 2012 8:22pm
The Musketeer wrote:
bpman wrote:
mine are:
4. parrot ICE
5. entreq FCG
gents ...
3. Crystal Headlights (Wipacs) with sidelights and H4 High output bulbs by PIAA
5. Entreq Fuel Cooler Guard .. protects the vunerable fuel cooler and other bit from stones
Post #123714 13th Feb 2012 8:49pm
ericvv
Post #123717 13th Feb 2012 8:59pm
