![]() | Home > Maintenance & Modifications > Your 5 Top Modifications |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
mine are:
1. additional security measures 2. rustproofing 3. crystals + h4 PIAAs 4. parrot ICE 5. entreq FCG |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
As you're in Switzerland, I guess you can use these! Illegal to use them in UK unless the visibility is less than 100 metres - which is of course about once every 5 years I guess it's either legal in Switzerland, or you get a lot of fog??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18048
One of my favourite targets of vitriolic hatred is the people who use front foglights when it isn't foggy, and I totally support any initiative by the Police to pull over people who drive with them on when it's illegal. Having said that, there is a strong argument for fitting front fogs on a Defender, since the headlights are so high up, and, especially if you have upgraded the headlights, backscatter in fog is a real problem. If you fit a good quality fog-beam light above the bumper, it will be low enough to work well as a fog light but high enough legally to not be a fog light, and therefore, provided it is adjusted so that it cannot dazzle oncoming drivers (and a properly adjusted fog light - in dry conditions at least - won't) can be used at any time. A lamp becomes a fog light in the eyes of the law by virtue of the fact that its centre is 600mm or less from the road surface. Anything greater than 600mm is not considered a fog light and is not subject to the fog, falling snow, or seriously reduced visibility restriction. On a related note, why do people wire foglights up so that they work WITH headlamps? If you need a fog light ON, you need headlamps OFF. A lot of the morons who drive with them on all the time could be stopped if type-approval required that foglamp activation disabled the headlights. And please, don't get me started on rear fog lights, the most useless and dangerous idea since the man with the red flag was done away with! |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
As mine is an XS it came with heated seats, heated screen, tow bar etc so in terms of things I've added;
1, Protection - Waxoyl and rubber mats inside 2, Security - Under cubby safe and pedal locks / etc 3, Extra 12v sockets for fridge and chargers 4, Variable wiper relay 5, Storage - Glove box, Roof bars. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
Rust proof
Sound proofing Head light upgrade Driving lamps Hardwire tom tom lead 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
top 5 for my family life puma 110 are:
1. sub, amp, mids and tweeters + ipod head unit stereo 2. rear nas step 3. variable wiper relay 4. rear door power strut 5. spotlights to "encourage" oncoming drivers to dip their lights top 5 for my single life td5 90 1. sub, amp, mids and tweeters +ipod head unit 2. J E Engineering remap and intercooler 3. twisted performance sports exhaust 4. koni suspension 1" drop 5. j e engineering spotlights in grille |
| The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459
1. Undersealing the chassis
2. Blue tooth phone kit 3. Securtiy cubby box 4. Sun visor 5. BFG's |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Not a lot of fog, but fog lights can be used legally when there is fog A lot of people here are using their front fog lights in combination with their main beam, but don't think police are doing much about it. I personally think if front fog lights are good quality and properly installed, AND ARE ADJUSTED SO THAT THEY DO NOT DAZZLE ONCOMING TRAFFIC, there is nothing wrong with using them. Too many after market fog lights are poorly installed, poorly adjusted. In that case police would have a point in stopping you. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
what is an entreq FCG? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
The big problem with using fog lights in the rain is the glare they cause off the wet road surface. I'm pretty sure that on modern cars fog lights are wired to switch off if main beam is selected. Not necessarily true for aftermarket installations though, I suppose. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Correct wiring for front fog lights, and how mine are wired by the local LR dealer, so that must be in line with EU and Swiss law (which are the same by the way): You can switch them on together with the parking lights and also with the dipped beam. They automatically switch off with the high beam turned on. I don't think that the last one there is actually mandatory. For instance my wife's VW has original ex factory HID lights, but her front fog lights do not switch off automatically with high beam engaged. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| The Musketeer Member Since: 07 Feb 2012 Location: United Kingdom Posts: 193
I have no idea what they are... I assume 3 is something to do with lights? |
gents ... 3. Crystal Headlights (Wipacs) with sidelights and H4 High output bulbs by PIAA
5. Entreq Fuel Cooler Guard .. protects the vunerable fuel cooler and other bit from stones Click image to enlarge |
don't think it is this parrot ICE, no? http://www.google.ch/imgres?q=parrot+ice&a...29,r:2,s:0 or this one? http://www.google.ch/imgres?q=parrot+ice&a...amp;zoom=1 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| All times are GMT |
