Home > Maintenance & Modifications > LED Interior Lights
Page 5 of 7 <1234567>
farmer giles
what is the general consensus on these replacement lights, then?
the bulbs with 6-16 leds within the bulb length are good, but the ones with a wire to a 48 panel is a bit more of a faff to fit?
cheers Thumbs Up
Post #122016 7th Feb 2012 8:46am
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Ha ha, mine arrived too, put them in, only one bloody worked!! Turned it round and hay presto Smile mine are the 16 led ones!! Good and brighter!! Especially for just over £3!!! 90 Puma HT
Post #122018 7th Feb 2012 9:00am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I just received some 16 LED ones from Ebay and while they are nice and bright, the bulb part is a little shorter than ideal for the clips and so is slightly loose. I couldn't find out what length the bulbs should be and guessed at 36mm. I will order up a 38mm version and see if it fits more snugly.
Post #122024 7th Feb 2012 9:28am
Jammer600
Gently bend the connectors in?! 90 Puma HT
Post #122025 7th Feb 2012 9:38am
Inigo
I did have a go, but they are very springy and I didn't want to bend them too much in case I want to revert back to the standard. Maybe it is being a little precious, but for another £2, I thought I'd get the right size.
Post #122028 7th Feb 2012 9:42am
bob neville
37mm 16 LED's fitted fine in mine OK, if anything they were too tight Thumbs Up
The retainers bend OK so you will not have an issue going back to the original, they are spring brass/steel ?
Light is excellent.
2013 Defender 90 CSW - sold
Post #122053 7th Feb 2012 11:37am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Mine too
Post #122063 7th Feb 2012 11:59am
ickle
Joe, if you nip round, I have a spare you can try - they are really good
Keith
Post #122182 7th Feb 2012 7:57pm
farmer giles
Hi Keith,
sorry for the late reply, little Ben has had a sickness bug yesterday and i was at home looking after him.
yep i would love to take you up on your offer. Can you pm me your address (not actually sure where you live Embarassed )
also, a heads up to say several vehicles have been broken into in the village - mainly Green Close i hear.
Cant make tonight but any other day after 7.15pm is convenient for me.
Cheers Thumbs Up
Post #122598 9th Feb 2012 9:19am
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
my 48ers arrived yesterday (after what seemed an eternity) fitted them late last night in the dark using just the illumination from the other interior light. got luck with polarity and shorting issues.
they provide a clear white light and not too bright imo, however aestetically they are less than pleasing witht eh 48 points of light glaring throught the fitting. they would have been better if they had been diffused more.
i bought 4 so that i would have spares and i am now thinking of piggybacking 2 together for the rear interior light in my 90.
we have young twins and getting them in and out of the baby seats is a nightmare in poor light with their little arms and legs flailing about.
Post #122602 9th Feb 2012 9:49am
JWL
Stuck some in mine today, a 6 led in the front, another 6 led above the 2nd row seats(put another OEM interior light in months ago) and a 48 led in the back light. Looks the business, just got to wait for dark now. For the sake of £4.28 it seems to be worth doing Thumbs Up
Post #123231 11th Feb 2012 2:21pm
LR90XS2011
fitted my 6 LED ones yesterday I also had to tweek the holders and blew a fuse but happy with the result and the 6 LED ones appear brighter than the previous lamps DEFENDER 90 TDCI XS,
Post #123238 11th Feb 2012 2:59pm
CarlW wrote:
Didn't do this myself but a piece of insulation tape on the metal back plate might avoid inadvertant contact (maybe not such a good idea if you put the original bulb back in due to the heat from the bulb).
Thanks to Carls' tip, I finally managed to fit my 48 LED lights today without blowing any more fuses Rolling Eyes
Here's a picture showing the difference between the old and new. It's quite difficult to photgraph the LED lights - in reality, the individual LEDs are more clearly defined.
They're nice and bright, although it does feel a bit like sitting in a fish tank at night Laughing Darren
Post #124623 16th Feb 2012 10:25pm
Lorryman100
Light is excellent.
Bob
Same here with mine. 16 led in front and the 48 in back makes a big difference over the standard bulbs. Thumbs Up
Post #124625 16th Feb 2012 10:38pm
robpenrose
I dont like the look of small patch of LEDs in the middle of the light lense, so Im going to double up mine too. If you fit them a particular way round, two will fit nicely together.
Will be nice and bright..
I had to order 3 more as the one of the first two that came had two LEDs that didnt work on the board Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #124655 17th Feb 2012 8:26am
