![]() | Home > Maintenance & Modifications > LED Interior Lights |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
do they work OK with the dimming ON/OFF feature ? DEFENDER 90 TDCI XS,
when I operate my central locking to lock the car my interior lights dim down to off, when I unlock they wind up to full on. they dont just go on and off DEFENDER 90 TDCI XS,
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Ah I see. Not sure what mine do...
Mine is a 2002 Td5, so may be different.. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1867 ![]() ![]() ![]() |
Yeah mine work fine with the dimming function 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Thanks ROSCO i too have now ordered some 6 LED ones
all the best Rob DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
And mine ![]() |
is it generally considered then that 2 x 48 LEDs are too much??
I might need to order a 6 or 16 bulb type for the front then, and stick just 1 x 48 in the rear light holder... Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
I think it was the dramtic change from what was to the 48 light units. Having given them a few days I've grown a little more accustom to them and there not as harsh.
Does anyone with more technical knowledge than me know if you'd be able to cut down the 48 light units? 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Ive ordered these.
http://www.ebay.co.uk/itm/2-Dome-16-SMD-LE...3a6ec5ed4a Looks like a compromise between the 24 ones and the 6 ones. Will see what there like when they arrive. Pete. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6164 ![]() ![]() ![]() |
Mine just arrived!
![]() Just going to go and fit them now. |
going to need pictures and reviews gents - please
Had mine in for 2 weeks now and once you adjust to the dramatic difference between the original and the replacement, its well worth the £1.50
![]() Only thing I'd say is put on your ![]() ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Hmmm.... They're OK, but.......
where the LED matrix is up against the inside of the outer plastic lens of the interior light, I just have a (very bright) square of light beaming through as opposed to a general "glow" that the old festoon bulb used to give. Might have to have a play on modifying the interior lamp unit to remove all of the old festoon lamp holder gubbins and enable the LED matrix to stick to the inner piece of the light, and thus away from the lens cover. If I do that, then there'll be plenty of room to fit two of the LED matrices.... uber bright!!! ![]() |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Not if you're dogging.....apparently. |
