Home > Off Topic > mounting your roof tent |
cheers for all your comments, still thinking of the ultimate solution .. will keep y'all posted
6th Feb 2012 7:51am |
Just build yourself a garden pergola/carport in your parking spot incorporating a strong enough cross beam to hoist the tent off. Train a few climbers up it(perhaps even have Bear Grylls camped on top)
Gives you a garden feature with a purpose |
6th Feb 2012 8:01am |
like your thinking JWL ... currently thinking of something like this ...
and attaching a lidl special ... 250kg hoist Cabled remote control with emergency shut-off switch For loads up to (kg): 250 Large operating range: swivels 180° Powerful 500 watt motor with thermal overload protection High-quality, durable gearbox for a long working life With automatic brake to secure load even during power outages Easy mounting with 2 clamps Steel cable length (m): 11.5 Automatic limit stop for winding and unwinding Includes 1 pulley with load hook and safety loop Max. projection (m): 1.1 Cable hoist max. load bearing capacity (kg): 125/250 (without/with pulley) Max. hoisting speed approx. (m/min): 8/4 (without/with pulley) Product consists of 2 boxes 3 year manufacturer’s warranty Contents & accessories not included http://www.lidl.co.uk/cps/rde/xchg/lidl_uk...date=28309 Last edited by bpman on 6th Feb 2012 11:35am. Edited 4 times in total |
6th Feb 2012 8:05am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Just use a pulley it's only 55KG
Or get this easy load system, can put a winch on if you need it but you won't with only 55KG http://www.karitek.co.uk/ELRRIntroMulti.html Seen these used for a number of applications .e.g tenders, dinghys etc |
6th Feb 2012 10:45am |
I must admit if I had the space I would build a strong pergola, plenty big enough to park under and put a polycarbonate roof on it. The roof wouldn't be on top of he structure but the sheets would be inset between the rafters and thus not noticable but allow a dry area underneath. A few climbing plants would then allow it to blend into the background, might even have a pit dug out as well Though if I had the type of place where I could do this then there would be a building put up as a workshop anyway with all the bells and whistles
6th Feb 2012 12:03pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2642 |
Steve
Check out www.roofbox.co.uk for the Thule roof box hoist. Only £50 so seems a simple and cheap solution. Mark |
6th Feb 2012 3:44pm |
interesting solution - thanks Mark steve |
6th Feb 2012 4:01pm |
collected hoist from Lidl's ... next A-Frame ...
7th Feb 2012 6:24pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
if you need something welding up give me a shout |
7th Feb 2012 6:30pm |
thanks Marcus - very kind offer .. I'll let you know |
7th Feb 2012 6:34pm |
today I collected a giant TP swing frame from a bay-merchant in Poole. "eBay search TP Swing".
Once taken apart, popped onto the roof of the defender and brought home. This measures 2m5 high. Too flippin cold to do any more today. Tomorrow ... take swings etc off the top and fit hoist and some photos then off flying with the boys |
11th Feb 2012 6:00pm |
Wow, like your style !
11th Feb 2012 7:17pm |
11th Feb 2012 7:37pm |
Cheers GREENI |
11th Feb 2012 10:29pm |
