Home > Off Topic > mounting your roof tent
Page 4 of 4 <1234
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
donmacn wrote:
Sulisuli - thanks - I know exactly what you mean, and I had kicked that idea around too.
I think it came a cropper when I started to think about the lengths of rope/wire rope involved. One thing I haven't mentioned above is that I don't want to have 4 ropes (or 2, or even 1) running diagonally from the roof blocks to the tie-off points at the wall. They'd just get in the way, and you'd be permanently ducking and swerving around them.
So, what I'll eventually have is a rope ( or 4) running straight up the wall to a pulley, and then across the roof to the 'lifting' pulley, and down to the tent.
So, if the tent had to be lifted say, 2m, and there was another 2m from one of the 4 lifting pulleys to the wall pulley, and then down to the winch, the spliced or combined ropes would have to pass through the wall pulley. As you said, I know what I mean, but I'm not sure I've described it very well!
Sako - a grand idea - but even if I had a JCB it still wouldn't fit in the garage!!
may not be possible in your garage Don, but this thing:
https://www.thule.com/en-gb/cargo-carrier/...t-_-572004
means that hoisting my 70kg tent off the car is truly a one man job
About £100 and worth every penny Thumbs Up 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #836257 9th Jun 2020 10:40pm
sako243
I think you'll find a JCB solves all your problems. It is after all quite good at digging and construction work... Whistle Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #836265 10th Jun 2020 1:12am
donmacn
^^^^^^ Rolling with laughter I think I see what you mean, and no doubt it would be a 'solution'... but I don't think my wife and the rest of the family would be too impressed!
Andy T - thanks for that - I'll have a look at that Thule kit, see if its sizes are within the space I have available.
Darren - I thought of that too!
The issue is just how much headroom I have - and why I was asking about small size pulleys.
This is where it needs to go, roughly between the two strip lights - once it's tidied....
I reckon I have about 60cm between the roof and my head. If it hangs any lower than that I'll be bashing my head against the feet of the roof bars. I could remove them, but then you're just adding another task that needs to be done to mount/demount the tent.
The bars and tent will be about 52cms, so I have about 8cms to accommodate whatever lifting solution I go for (short of getting the JCB in to remove the wall and dig out the floor.... Shocked )
JST's pulleys will do that, especially as they could be fitted outside the area of the tent, allowing it to be lifted nearly flush with the garage roof.
I don't think I've the clearance to get a lifting frame in there, though something along those lines was among my earlier thoughts - maybe getting a frame welded - but I'd still need room for whatever roof mounting there is, and the hook/shackle onto the frame.
I'll keep thinking, but at the moment, unles the Thule thing fits, and looks up to the lift, then the hand pull, with s pulley arrangement int each corner is closest to the KISS principle. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #836285 10th Jun 2020 8:31am
Hmm, with a suitable arrangement of pulleys, the ropes could be led off to one side across the ceiling and down the wall. Or mount a hoist like mine to one side at the top of the wall.
Or fix a frame to the ceiling to take the tent, hinged at one end to allow the other end to drop down. Slide on tent and lift up. A bit like a spare wheel Tufflift, where you are only lifting half the weight.
Lots of solutions but some ingenuity required, probably with input from Heath Robinson Laughing Darren
Post #836288 10th Jun 2020 8:45am
donmacn
Very Happy Very Happy Exactly!
In fact the hinged cage idea ( with a very Heath Robinson ethic!) is something I've just tried in the cellar adjacent to the garage. That would work. But in there the headroom is much less and the current tent more or less enters the cage at ground level.
The problem is that this cellar is entered via a pedestrian door, and up a step. My son and I managed to get the tent in there and onto the cage, and up against the joists. But he won't be home too much (short of another pandemic shutting down his Uni course) so it has to go somewhere I can manage this solo. A hinged cage in the garage I've pictured would be just too high and difficult to do myself.
The pulley arrangement is what I described about 4 or 5 posts up, but as I said, it's the kind of thing you have to see to properly understand what someone's describing. This idea is currently in the lead! Donald
in the past..
Post #836292 10th Jun 2020 8:55am
How about a combination of the two? A cage that's lifted by a single pulley at one end? It would certainly simplify the rope work. Darren
Post #836297 10th Jun 2020 9:13am
rallysteve
How about just jacking the vehicle up with a couple of trolley jacks, a couple of ratchet straps around the tent and ceiling and let the vehicle back down?
Post #836301 10th Jun 2020 9:56am
My solution! There is a couple of these on Ebay at the moment, if you're inspired.
Post #836333 10th Jun 2020 1:52pm
donmacn
Laughing A bit of 'mission creep' perhaps??
Nope. The die is cast. I've ordered 8 pulleys. Four for the 'lift' and four more to run the rope along the roof and down the wall.
Can't see progress being lightning fast as I'll have to get the garage cleared first - and the bulk of what's there is a kitchen that needs to cross the minch to a hebridean island.... with no ferries running.... I daren't ask for any suggestions about that!! Donald
in the past..
Post #836394 10th Jun 2020 6:08pm
Here's a different way of doing things:
https://www.overlandexpo.com/whats-new/rub...cs-pricing
Post #841488 3rd Jul 2020 11:59am
Cunning!
Post #841494 3rd Jul 2020 12:12pm
Page 4 of 4 <1234
