Home > Maintenance & Modifications > steering guards
Page 6 of 6 <123456
farmer giles
hi darren,
having a closer look at your picture looks like a c shaped metal plate has been welded to the front bumper with the drop pin and safety chain being visable.
i did see a portugese LR in yellow or sand colour - i don't think it was military - with air con and military bumper. can't remember if the image was on this site or google images. Bugg@red if i can find it again, though.
does killer 90 work for Foley specialists? maybe he can help?
Post #120094 31st Jan 2012 3:13pm
Killer90
Site Sponsor
yep foley man to the rescue Laughing had a quick read but a little lost Laughing what is it your trying to do fella Thumbs Up
Post #120132 31st Jan 2012 5:46pm
farmer giles
hi killer,
do you have any pictures from work of land rovers with air con AND military front bumper?
some new 130 military ambulances have them and we want to see the front grille detail where the drop pin goes. cheers if you can help
Thumbs Up
Post #120289 1st Feb 2012 10:02am
Zagato
LR Centre Ltd do quite a range. I think they are the same as LR parts Wink
The key is to have a clear website with good info, which is easy to navigate with good pictures, I give up with other companies Rolling Eyes
http://www.lrparts.net/sp/cat/DEFENDER/sub...UARDS.html Thumbs Up
Post #120372 1st Feb 2012 5:34pm
Killer90
Site Sponsor
yer ill try and get hold of some matey, i know we have just got in 4 ambulance landys so they might even have them if i find anything ill post the pictures up Thumbs Up
Post #120383 1st Feb 2012 5:58pm
Killer90
Site Sponsor
right hope this helps i got this pic but its a little small cant enlarge it, as the pic shows i think its a piece made straight from the factory there is a mesh grill the the plastic land rover grill but the fibre glass air con grill has been cut and moulded from factory, i think what you could do which would work is cut your original air con grill cut the piece section out and fit a aliminum plate behind and fix it either end with the same screws which go through the plastic grill into the air con grill peice spray it up and it should look quite proffesional Thumbs Up
Post #120404 1st Feb 2012 6:28pm
farmer giles
cheers killer,
that is exactly what i'm looking for. If you every get a spare one at work please pm me as i would be very keen to buy the grille.
Thumbs Up
Post #120550 2nd Feb 2012 8:28am
Lorryman100
Lorryman100 wrote:
I have a safari equip one supplied by Brendan (leeds). It has a 2"receiver which takes a recovery billet with a shackle and also allows the fitting of a drop plate to fit a tow ball onto. There are also two very substantial lugs on either side that can take a shackle.
It is a very substantial lump of metal and I have been told it would make a very good mud plough if you needed recovered from the rear from deep mud. Wink
Brian.
Some more pics with the 2" billet and shackle, plus the two eyes fitted with shackles for a bridle.
It is all kept in the Puma, in a box under the rear seats.
Post #120633 2nd Feb 2012 3:48pm
Killer90
Site Sponsor
yer any ones that might be broken for bits will let ya know Thumbs Up
Post #120659 2nd Feb 2012 6:07pm
farmer giles
cheers killer Thumbs Up
Post #120829 3rd Feb 2012 9:57am
Page 6 of 6 <123456
