Home > Maintenance & Modifications > steering guards |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
hi darren,
having a closer look at your picture looks like a c shaped metal plate has been welded to the front bumper with the drop pin and safety chain being visable. i did see a portugese LR in yellow or sand colour - i don't think it was military - with air con and military bumper. can't remember if the image was on this site or google images. Bugg@red if i can find it again, though. does killer 90 work for Foley specialists? maybe he can help? |
31st Jan 2012 3:13pm |
hi killer,
do you have any pictures from work of land rovers with air con AND military front bumper? some new 130 military ambulances have them and we want to see the front grille detail where the drop pin goes. cheers if you can help |
1st Feb 2012 10:02am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
LR Centre Ltd do quite a range. I think they are the same as LR parts
The key is to have a clear website with good info, which is easy to navigate with good pictures, I give up with other companies http://www.lrparts.net/sp/cat/DEFENDER/sub...UARDS.html |
1st Feb 2012 5:34pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
yer ill try and get hold of some matey, i know we have just got in 4 ambulance landys so they might even have them if i find anything ill post the pictures up
1st Feb 2012 5:58pm |
right hope this helps i got this pic but its a little small cant enlarge it, as the pic shows i think its a piece made straight from the factory there is a mesh grill the the plastic land rover grill but the fibre glass air con grill has been cut and moulded from factory, i think what you could do which would work is cut your original air con grill cut the piece section out and fit a aliminum plate behind and fix it either end with the same screws which go through the plastic grill into the air con grill peice spray it up and it should look quite proffesional
1st Feb 2012 6:28pm |
cheers killer,
that is exactly what i'm looking for. If you every get a spare one at work please pm me as i would be very keen to buy the grille. |
2nd Feb 2012 8:28am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Some more pics with the 2" billet and shackle, plus the two eyes fitted with shackles for a bridle. Click image to enlarge Click image to enlarge Click image to enlarge It is all kept in the Puma, in a box under the rear seats. Click image to enlarge |
2nd Feb 2012 3:48pm |
yer any ones that might be broken for bits will let ya know
2nd Feb 2012 6:07pm |
cheers killer
3rd Feb 2012 9:57am |
