Home > Puma (Tdci) > Puma EGR blanking plate FREE :-) |
I'm not sure, but what I do know from previous experience and from other postings on here is that the EGR Valve is a proverbial irksome, troublesome, temperamental, unreliable, prone to kicking up a fault at any time, intermittantly operating....piece of cr4p engineering that as soon as someone comes up with a viable solution to get rid of totally without a MIL light illuminating I'll race you to the 'checkout' with one. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Sep 2010 1:46pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Think my egr is playing up getting surging
18th Sep 2010 6:43pm |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 |
Same - and when LR recently replaced the valve - it was all good again - but now, 2 months later - surging. Who else has had this issue caused by bunged up EGR's? Or is this why everyone is blanking them off? PS - cleaned my MAF sensor - I'll let you know if this stops the surging - which is really just a slight miss when feathering on/off throttle. |
3rd Oct 2010 11:27pm |
If you've got the time and inclination it is worth whipping the EGR Valve out periodically and giving it a clean in brake cleaner I reckon!!!!
Especially if you're out of warranty! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th Oct 2010 6:31am |
Will do - although I have 18 days of warranty left - then my 3 years extended warranty kicks in! |
4th Oct 2010 11:11am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4729 |
Just a thought. Instead of installing a blanking plate with a hole in it, would it be feasible to put a small length of piping of the same diameter as the hole in the blanking plate into the hose feeding into the EGR. Once inserted the small length of pipe or tubing could be held in place with one or two hose clips. This would have the effect of restricting the amount of gases by funneling them through a smaller aperture-which is what the blanking plate does. It would be easier than dismantling the EGR. This is probably a non runner and there is probably a reason as to why it would not work. No doubt someone will explain why. But it was just a thought. 1982 88" 2.25 diesel
6th Oct 2010 6:09pm |
Hans Member Since: 12 Jan 2010 Location: Lot, France Posts: 45 |
I had it replaced 2 months ago and the new one starts surging again. Hans http://www.orlaya.fr |
17th Nov 2010 10:09am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2438 |
14 mm plate and runs a lot smoother and responsive Puma 110" SW
25th Feb 2011 12:56am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5045 |
I think if im going to replace it (and note the MAF does improve everything in my experience) i would go for a software update rather than a plate. Mike |
25th Feb 2011 7:41am |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
For anyone fitting the blanking plates, rather than removing the bonnet, you can get better access than normal by tying it back with length of rope.
25th Feb 2011 7:46am |
But pay attn not to dent the bonnet with the wiper blades! Puma 110" SW
25th Feb 2011 10:30am |
bartsimp Member Since: 18 Jan 2012 Location: France Posts: 41 |
I'm resurrecting this post Are you still so enthusiast about the engine being quieter? If so at what RPMs are you talking about? Last, who now sells good td4 blanking systems? Last edited by bartsimp on 23rd Jan 2012 4:19pm. Edited 1 time in total |
23rd Jan 2012 4:10pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
The early blanking option/testss have now been updated with software delete option inside a remap.
Pete |
23rd Jan 2012 4:18pm |
meaning you don't have to physically blank it and do it via software?
23rd Jan 2012 4:19pm |
