![]() | Home > Puma (Tdci) > Engine lift bracket.. GRRRRRR |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
I cannot realize which is the problem
![]() Thanking in advance ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Quite a few posts on this. You may have a red engine lifting bracket at the top/rear of the engine that can vibrate lose. Easy to take off, the later models don't seem to have them left on! If you cannot easily see one, you won't have it, they are obvious to spot.
Dealers should remove them - if not it easy to spot. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
racer111 Member Since: 06 Jan 2012 Location: Hamburg Posts: 12 ![]() |
yeah my mate had a similar thing happened and it cost him a fortune......good advice here I wish heŽd known about it...how much do you think it normally costs? is there anything you can do driving-wise to stop it happening?
Check out this website where I bought really cheap clothes and shoes. Last edited by racer111 on 10th Feb 2014 3:41pm. Edited 2 times in total |
As Zag says you can't miss it, if it's there it's a steel plate with a large hole in it that's painted bright red and you will find it at the back of the engine / head. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
it's ok on LHD models, not that it helps you much ..
Helps me ![]() But shout it at them in German because life is also terrifying and confusing... |
I mentioned this last year,it can also wear theough the aircon pipe on XS models 2.4 90 XS
Thanks all for the information.
Looking at photo of my engine bay (don't care the green circle) I can see the red bracket in the upper right corner (blue arrow). I will remove it asap! ![]() |
roadracingtog Member Since: 03 Nov 2011 Location: Cheshire Posts: 97 ![]() ![]() ![]() |
Mine is still attached too. I shall remove it tomorrow.
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Why not just nip it up to the correct torque? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
The bracket? When it's fitted it can cause chafing to the pipework that runs very close / over the top of it. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 ![]() ![]() ![]() |
Mines still attached, had a quick glance earlier looks a right pain in the arse to get to to take it off! 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
