Home > Puma (Tdci) > Engine lift bracket.. GRRRRRR |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
Had a look under the bonnet of the 2.2 yesterday It's a lot busier in there
The silly rear door handle with holes in it made me laugh - somebody must have been really bored one afternoon |
17th Jan 2012 8:43am |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
Two bolts??? Mine has just the one, now anyway .
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
17th Jan 2012 9:50am |
One has already fallen out!
17th Jan 2012 3:15pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Mine doesn't seem to have one - is it somewhere hidden for us LHDs? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
17th Jan 2012 3:29pm |
Not hidden at all. When you watch the engine from the driver side of the LH drive vehicle. it is a big bright red bracket located close to the bulkhead. If it is there, can't miss it. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
17th Jan 2012 8:25pm |
Mine didn't have one either they stopped putting them in on later models |
17th Jan 2012 10:11pm |
Bearcat Member Since: 09 Dec 2011 Location: Dublin Posts: 57 |
I just put pipe insulator around the pipe that rubs off the red hoist mount. My puma has 63k miles and pipe wasn't chaffed. Current...07 90 Puma commercial
Porsche 930 1988 (laid up) Previous Td5 90 & V8 90 |
18th Jan 2012 7:24am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Took my 90 to Stratstones in Burnham last week.. The techie had a look see, and said, "Yup, it's f*$ked.." Took the keys, couriered a new hose in, swapped out the dud, took off the bracket and refilled the coolant.. All in about 4 hours.. And he also found leaking swivel seals, agreed to replace the headlight surrounds, front mudflaps and rear window... It went in today for the bits under warranty.. Pick it up in the morning... I'll shout loud if any work aint been done!!! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
23rd Jan 2012 9:08pm |
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 |
Just to say thanks for the tip. Checking the fluids in preperation for prospective weekends snow, I decided to remove the bracket. Despite tightening the bolts 2 months ago before I read this thread, one had worked loose enough that 2 secs finger tip work removed it. Needless to say I took the off this time!
This should be a bloomin recall notice surely? |
2nd Feb 2012 5:20pm |
PK1 Member Since: 19 Oct 2012 Location: Gloucestershire Posts: 96 |
Heard a noise - looked under the bonnet and found a red bracket. New to all this so investigated this forum only to find out the recommendation is to remove bracket...........so being keen went straight out to investigate further. Touched red bracket and it fell off!!! OMG how lucky I investigated - Thanks peeps!!
19th Oct 2012 6:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20123 |
Good job you did then or it could have been in someone's windscreen behind if it fell onto the road. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
19th Oct 2012 6:45pm |
who legally would be responsible for that ? the owner or land rover ? |
19th Oct 2012 6:47pm |
Is this on a 2.2 - where should I be I looking? |
25th Feb 2015 10:52am |
^^ Puma 2.2 rear door handle. It is the environmental guys in Solihull's solution to Defender weight saving. The Puma 2.4 has a solid door handle without holes.
But then those same Solihull environmentalists witth the Puma 2.2 added a rubber lead to the fuel cap. So by this they erased 50% of those weight savings again. eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
25th Feb 2015 11:13am |
