![]() | Home > Puma (Tdci) > Engine lift bracket.. GRRRRRR |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
It'll fall off on its own given enough time
![]() Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
wurzell Member Since: 29 Jan 2011 Location: oxfordshire Posts: 141 ![]() ![]() |
hi i read this post about 15 mins ago and it stirred me up to do it just been out there less than 5 mins job now done
Just checked my heater hose by the lifting bracket (still fitted) and it is fine.
The hose on mine is held away from the bracket by a plastic clip that goes round the hose and the other end is clamped around a wiring harness. However, my turbo heat shield was undone - now fixed ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
hi bob
Thanks Paul
![]() Just removed mine, not very difficult especially as the bottom bolt was not tightened up, I didn't have to touch it with a spanner ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
I apologize for such a dumb question, but once the bracket is removed, the bolts can be discarded or they must be reinserted and tightened into the engine ?
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Tape them to the bracket and hang the bracket up somewhere, somebody will be looking for an engine bracket in 20 years time
Thanks for your answer!
nikojo Member Since: 05 Aug 2011 Location: Madrid Posts: 75 ![]() |
another reason to remove it..........mine ate the f-ing harness and started going into limp mode on certain turns at certain speeds..........could not figure out the problem as it was sporadic.
then were able to reproduce the problem by manually "moving" the harness and there it was. HATE THE RED BRACKET!! ![]() |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Just checked on ours, bracket is still there, but there doesn't appear to be any pipes / wires going anywhere near? It's also tightly bolted up.. Do I still need to remove it?
Alex 110 Tdci Double Cab |
Same with me. Red engine bracket is there. Nothing comes closer than 3 or 4 cm, so presume no need to remove it. Who knows, one day in the future it might serve its purpose.
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
For the sake of two minutes with a 10mm spanner or ratchet I think it's worth removing and storing away in the vehicle anyway
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Going by what many others have said the bolts work loose through engine vibration. It just make sense to avoid future problems. The brackets are now taken off during production. |
