Home > Td5 > Engine loom routing
Arbman Al
Engine loom routing
Hi All
I am after some directions for the route of the engine loom from the ecu under drivers seat.
Cheers...Al 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #113110 6th Jan 2012 10:25pm
bell-auto-services
It comes out of the seat box UK drivers side, accros the top of the transfer case side ways a little, then backwards towards the rear bulkhead and up. You cant really route it wrong.
Pete
Post #113118 6th Jan 2012 10:54pm
Arbman Al
bell-auto-services wrote:
It comes out of the seat box UK drivers side, accros the top of the transfer case side ways a little, then forward towards the blukhead and up. You cant really route it wrong.
Pete
Thanks for reply.
I've currently got it coming though the gbox tunnel on nearside into engine bay. Then across back of bulkhead then not sure where to go from there??
Does it fix to the wheel arch or run along the top of the chassis or somewhere else??
Post #113246 7th Jan 2012 4:43pm
roel
How it runs on my RHD 2003 90. I will talk left and right seen frrom the back of the car to the front.
The loom runs from below the right seat over the gearbox to the left chassis rail. from there to before the bulkhead and then over the bellhousing to the right again. The it follows the Right side off the engine to the front.
I installed from the front to the back I found that a more logical way off doing things.
I placed my Ecu to the bulkhead between/behind the front seats. The only wire to extend is the wire to the high low sensor. Roel
2003 90 Td5 (2009-now)
Post #113249 7th Jan 2012 4:52pm
bell-auto-services
I just edited my first post as i typed fowards instead of backwards which made it confusing sorry Embarassed
Post #113252 7th Jan 2012 5:06pm
Arbman Al
Ah! Starting to make more sense now.
So it fixes to the back of the engine rather than on the bulkhead?
Also there are 3 or 4 plugs in the loom that look like little spark plug leads, what are they for as can't see anything for them to plug in to?
Cheers.....Al 1996 Defender 130 converted to TD5 and auto
Post #113284 7th Jan 2012 6:08pm
bell-auto-services
Al lets start again as I think their is some confusion at my end.
Do you want to run the loom as factory ? or do you want to relocate your TD5 ecu from under the seat?
Post #113298 7th Jan 2012 6:47pm
Arbman Al
Hi Pete,
I have located the ecu under the drivers seat. I think I've pretty much got it sussed now, as I was thinking it should be fixed to the bulkhead behind the engine, rather than on the back of the engine itself.
What are the spark plug looking leads for? and also Does the under seat fusebox next to the ecu mount onto a bracket of some kind - a photo wopuld be handy....
Post #113304 7th Jan 2012 7:12pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Hi the leads that look like spark plug leads go to the glow plugs
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #113305 7th Jan 2012 7:15pm
bell-auto-services
Ahh ok then my first post after editing it was wrong info sorry.
Yes the fuse box sits next to the ecu on a black tin bracket. I dont have any pictures but if you are stuck on Monday ill get one from my Defender for you. The 4 spark plug type leads are the heater plug wires and slip on to the end of the pugs sort of above the inlet manifold next to the head.
Pete
Post #113306 7th Jan 2012 7:15pm
Arbman Al
Pete
Nice one! Thanks for the reply. Best plug in the glow plug wires then now I know what they are Rolling Eyes
Post #113311 7th Jan 2012 7:32pm
