![]() | Home > Td5 > Engine loom routing |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
It comes out of the seat box UK drivers side, accros the top of the transfer case side ways a little, then backwards towards the rear bulkhead and up. You cant really route it wrong.
Pete Last edited by bell-auto-services on 7th Jan 2012 5:05pm. Edited 2 times in total |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 ![]() |
Thanks for reply. I've currently got it coming though the gbox tunnel on nearside into engine bay. Then across back of bulkhead then not sure where to go from there?? Does it fix to the wheel arch or run along the top of the chassis or somewhere else?? Cheers...Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
How it runs on my RHD 2003 90. I will talk left and right seen frrom the back of the car to the front.
The loom runs from below the right seat over the gearbox to the left chassis rail. from there to before the bulkhead and then over the bellhousing to the right again. The it follows the Right side off the engine to the front. I installed from the front to the back I found that a more logical way off doing things. I placed my Ecu to the bulkhead between/behind the front seats. The only wire to extend is the wire to the high low sensor. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I just edited my first post as i typed fowards instead of backwards which made it confusing sorry
Ah! Starting to make more sense now.
So it fixes to the back of the engine rather than on the bulkhead? Also there are 3 or 4 plugs in the loom that look like little spark plug leads, what are they for as can't see anything for them to plug in to? Cheers.....Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
Al lets start again as I think their is some confusion at my end.
Do you want to run the loom as factory ? or do you want to relocate your TD5 ecu from under the seat? |
Hi Pete, I have located the ecu under the drivers seat. I think I've pretty much got it sussed now, as I was thinking it should be fixed to the bulkhead behind the engine, rather than on the back of the engine itself. What are the spark plug looking leads for? and also Does the under seat fusebox next to the ecu mount onto a bracket of some kind - a photo wopuld be handy.... Cheers...Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 561 ![]() ![]() ![]() |
Hi the leads that look like spark plug leads go to the glow plugs
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Ahh ok then my first post after editing it was wrong info sorry.
Yes the fuse box sits next to the ecu on a black tin bracket. I dont have any pictures but if you are stuck on Monday ill get one from my Defender for you. The 4 spark plug type leads are the heater plug wires and slip on to the end of the pugs sort of above the inlet manifold next to the head. Pete |
Nice one! Thanks for the reply. Best plug in the glow plug wires then now I know what they are ![]() Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
