Home > Maintenance & Modifications > steering guards |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
which have you got im after one but with so many out there im i would like one with towing eyes.
5th Jan 2012 9:13pm |
genuine land rover
5th Jan 2012 9:18pm |
No towing eyes on that one, BPMan. Darren
5th Jan 2012 9:29pm |
looks good |
5th Jan 2012 9:33pm |
simply use the existing LR ones that are factory fitted |
5th Jan 2012 9:34pm |
I'm guessing that's an ICE thing then? Doesn't help on regular models though, unfortunately.
Unless something substantially better comes up, I plan to fit the Shadow guard from First Four Off-road which has 10mm side plates with towing eyes and an 8mm ali. main plate. Having said that, it does look very similar to the one fitted to Killer90's above. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
5th Jan 2012 9:42pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
cheers tolley and yer Anorak thats the one i have got shadow aluminum steering guard its identical so must be, the terraifirma one which i thought i had is slightly different and doesnt have holes in the bottom piece cheers for that
5th Jan 2012 9:53pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Please, please remember that there is a BIG difference between towing eyes, lash down eyes and RECOVERY eyes.
To the best of my knowledge, Land Rover do NOT fit RECOVERY EYES as standard at the front of Defenders. They do fit LASHING EYES. Lashing eyes are designed for lashing down Defenders to transporters/containers etc. These LASHING eyes are NOT designed for Recovery purposes. Be wary of some of the aftermarket steering guards with inbuilt recovery eyes, especially with some of those on ebay. Yes I have photos of twisted lashing eyes used for recovery. Also have photos of el cheapo ebay specials which have failed at the mounting points. Buy cheap? Make sure that you are rich enough to buy twice over. Forget looks, start thinking of practicalites! Do YOU know the difference between a lashing eye and a recovery point? What about the quality of the bolts/chassis that things are attached? Do you know the difference between a tow strap and a recovery strap? Do you understand the forces involved? Brendan |
5th Jan 2012 10:16pm |
oh, I sit corrected, I have lashing eyes
5th Jan 2012 10:18pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Good job Brendan was here to point it out Seriously, you cannot use them for recovery - highly dangerous (no matter what Defender of the Earth says ) |
5th Jan 2012 10:26pm |
Mine doesn't break down so I'll probably take them off |
5th Jan 2012 10:29pm |
What happens if you use a lashing eye for recovery
Click image to enlarge Do you want to trust your vehicle and possible life to cheap nasty gear? Click image to enlarge Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
5th Jan 2012 10:32pm |
.....and have some proper RECOVERY eyes fitted! Just finishing your sentence off BP Brendan |
5th Jan 2012 10:47pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
I have the standard land rover bar type guard fitted and it suits my needs well. Its cheap and easy to fit, doesnt weigh much and gives good protection for green laning and 'normal' off roading. The down side is that it isnt much good for bouncing off rocks and extreme off roading. On the plus side though its doesnt act like a plough when your going backwards.
Pete |
5th Jan 2012 11:33pm |
