![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Mouta Member Since: 24 Mar 2025 Location: Muscat Posts: 17 ![]() ![]() |
Primarily interested in "21. Cell Phone Signal Boosting" - has anyone successfully obtained the necessary CCF modification for this? |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 333 ![]() ![]() ![]() |
Cellphone signal boosting needs additional hardware, specifically:
1 - wireless charger module (has integral antenna coupler) 2 - the top of the centre console needs modifying or replacing to fit the charger module 3 - RF amplifier module 4 - external antenna, fits behind LH rear light trim Generally if this is not fitted from factory the wiring is not present so adding this is not just the trivial exercise of changing "MultiCAN-854 Phone Signal Booster" Defender 110 D300 X-Dynamic HSE MY22 |
Really appreciate the quick and detailed reply!
We’re all pretty used to the Defender’s noisy cabin by now, but I’m curious if there’s a way to modify any CCF settings to enable something like Speed-Sensitive Volume Control which automatically adjusts audio volume based on the vehicle’s speed to compensate for road and wind noise. That would be a treat!
