Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 110 of 110 <123 ... 108109110
CMG
Germany
This definitely is what my car does as well. Maybe there are different versions about? Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1064615 3rd Apr 2025 6:57pm
Mouta
Oman
Adamalli wrote:
I have also been able to enable the Dynamic Driving Mode and the Dynamic-I Setting icon, advance tow assist, and 007 startup screen.
I already have the wifi hot spot, though I think i found the setting for that, and terrian response 2.
What I would really like is adaptive cruise control. I found the setting for this and when enabling it I get the distance setting buttons to light up, but get an error about emergency breaking not working. When viewing the faults for the vehicle there is a fault for the ABS. I haven't figured out how to get past this.
Does anyone know how/if there is a way to export your current cars CCF. I would like to keep track of what I am doing in a spreadsheet but for the life of me can't see a way to export the current CCF.
Over on landroverforums.com there is a guy that has figured out how to activate a lot of items, though he uses the official diagnostic tool and pathfinder software. He charges for his services, which I am sure is worth it to some people and those who want things now. I like to tinker so don't mind trying to figure things out myself. Point being is the list below is what I think we should be able to figure out as a group at some point.
1. wifi hotspot.
2. Last user mode disables stop start on p300 defenders permanetly on or off with the simple touch of a button even after ignition cycles.
3. Adaptive cruise control with que assist including full stop and go.
4. Adaptive speed limiter.
5. Adaptive high beams with configurable settings.
6. Advanced off road package.
7. All terrain prgress control & configurable terrain response!
8. On demand center locking differential with the touch of a button.
9. Global window close from your key fob.
10. Global window open from your key fob.
11. Sunroof open from your key fob.
12. Sunroof close from your key fob.
13. Tailgate pop open from your key fob.
14. Bright Lights/High beams on with your fog lights on. (Not allowed in North America buyt we do it)
15A. Configurable dynamic mode (Even the V8 and/or 007 Defenders dont have this!)
15B. Proximity locking & unlocking works on some model years.
16. Dynamic mode- controls throttle, suspension, steering, braking settings.
17. Timers and G force meters on the navigation system.
18. DAB radio and XM radio activation. (Needs a subscription eventually.)
19. Engine noise cancellation.
20 Engine sounds through the speakers disabled.
21. Cell Phone signal boosting.
22. Advanced Tow assist.
23. Activity Key as long as you have the correct MHZ frequency key.
24. Needs hardware! Adding center console fridge freezer.
25. Needs professional installation and wiring then we can activate the rear differential as an oem add on after the fact. Yes fully OEM with the advanced off road pack after you buy the oem parts and have them professionally installed we can activate the differential to be fully oem integrated.
26. 12.3 inch Navigation center console upgraded AFTER you buy and have installed the 12.3 inch screen we can activate it.
Primarily interested in "21. Cell Phone Signal Boosting" - has anyone successfully obtained the necessary CCF modification for this?
Post #1064977 8th Apr 2025 10:39am
Fifth Horseman
Cellphone signal boosting needs additional hardware, specifically:
1 - wireless charger module (has integral antenna coupler)
2 - the top of the centre console needs modifying or replacing to fit the charger module
3 - RF amplifier module
4 - external antenna, fits behind LH rear light trim
Generally if this is not fitted from factory the wiring is not present so adding this is not just the trivial exercise of changing "MultiCAN-854 Phone Signal Booster" Defender 110 D300 X-Dynamic HSE MY22
Post #1064995 8th Apr 2025 1:51pm
Mouta
Oman
Really appreciate the quick and detailed reply! Thumbs Up
Post #1065372 13th Apr 2025 6:06am
Mouta
Oman
We’re all pretty used to the Defender’s noisy cabin by now, but I’m curious if there’s a way to modify any CCF settings to enable something like Speed-Sensitive Volume Control which automatically adjusts audio volume based on the vehicle’s speed to compensate for road and wind noise. That would be a treat!
Post #1065548 15th Apr 2025 8:41am
