![]() | Home > General & Technical (L663) > Rear hinges |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3031 ![]() ![]() |
Nobody done it?
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 78 ![]() ![]() |
Not done it but interesting as I have a creak at the back so will investigate and let you know if I come up with anything
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 243 ![]() ![]() |
I am not sure why cars nowadays have no hinges lubricated. I have spread lithium grease from day one on my defender. Some of my more techy friends with engineering background suggest is not needed. However it is harmless to spread some old fashion grease…and makes me feel better
![]() You can also use dry silicon spray if you feel rich… |
l've managed to oil the hinges with spray grease.
However it didn't stop the creaking. |
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 60 ![]() ![]() |
please try lubricating the sealing rubbers, I also had a squeaking sound from the rear and it helped me
the sound is when you are closing/opening doors?
No it's when l drive slowly over uneven ground.
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 297 ![]() ![]() |
Ditto Sasa's post, I routinely dress all the door seals with Gummi Pflege silicone lubricant. It seems to keep the creaks at bay. 23.5MY 90 V8 Carpathian grey
