![]() | Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit |
Darrant1234 Member Since: 02 Nov 2024 Location: Wakefield Posts: 20 ![]() ![]() |
Hi thanks for the reply, I’m not sure what Else can be done so I’ll take a look.
GBstu Member Since: 07 Nov 2024 Location: Lyon Posts: 4 ![]() ![]() ![]() |
I'm looking to do this mod on my 2024 110. I see on this LR parts website that the clearsight mirror part number LR140339 has been replaced by 530123488 https://parts.landroverparamus.com/oem-par...NDAzMzk%3D
There are a few folks selling it new on ebay in Europe for 550 euros, can anyone confirm that 530123488 is correct? Cheers |
Hi Part sounds right from the description, when i got mine though it found it brand new on ebay using the LR code.
Side note local JLR independent should be able to code mine to work , so im going to take it in this week at point. |
So the specialist was unable to code it using topix and didnt want to edit CCF files as they can break cars. Ordered a gap tool so ill have a play
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 247 ![]() ![]() |
Just turn it on easily in seconds with a gap tool. MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Thanks all. Gap tool arrived and it’s now working. Took me longer to register the tool than it did to make the change.
I got an evoque antenna. I wonder if the defender one has the camera slightly more angled down. Works well though. No more looking at a rear head rest or top of spare wheel. |
You know you can adjust the camera up and down with the buttons on the bottom of the mirror? MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Yeah it’s already all way down, it works well I think I’m just used to seeing it on an evoque which is much lower down.
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 103 ![]() ![]() |
Brilliant instructions I have fitted mine today.
https://www.defender2.net/gallery/albums/u...Camera.jpg I didn't buy the Land Rover repair Cable LR164584. I bought this cable from Amazon https://www.amazon.co.uk/dp/B0C1GVRBGG?ref...asin_title and the cable from Ebay https://www.ebay.co.uk/itm/325234838660 Which is about £10 I got a mirror and camera of ebay for around £500. It took me about 2 hours to complete it. |
isugoo Member Since: 17 Feb 2025 Location: California Posts: 5 ![]() ![]() |
Hi @ThunderBob and other US Defender Owners (or other savvy DIY guys) who did the retrofit. I have a few questions are reading the entire threads carefully (hopefully, experience guys don't think I'm another spoonfed newbie... please forgive me)
It looks like parts I need are: 1. LR1403340 (Camera with HomeLink) 2. LR164584 (LR Wire) 3. LR140535 (For US, with Nav, Sirius XM, Radio antenna built in) 4. LR117853 (Camera Cover) 5. Fakra Extension Cable (Female to Female) - 3mm 6. Coding My questions are: #3. LR130535. Can you confirm if this is the right part that works with built-in Nav and SAT? #5. Fakra cable FEMALE to FEMALE seems the crucial part but for 90, what length I do I need to buy? it looks like 3 meters are too long for Defender 90. Please help me. As I secured the used mirror and a local coder, I'm trying to order everything quickly to join the club. Thanks all world of Defenders in advance!
ThunderBob Member Since: 23 May 2024 Location: Kentucky Posts: 17 ![]() ![]() |
@isugoo Welcome to the forum! LR140535 should work for you. There should be a total of five Fakra cable inputs. All units (to my knowledge) include the Navigation antenna.
![]() Click image to enlarge You should be able to pick up a used unit through eBay at a reasonable cost. Be sure that it is a North American unit to get the Sirius/XM input. You are correct 3 meters is a bit too long, 1 meter should be more than adequate. I purchased the 3 meter cable and ended up coiling up the cable and stuffing it above the headliner. Take your time, don’t force anything. You’ll find the installation pretty easy! |
Hi ThunderBob,
Thank you for confirming that 140535 is correct part and Fakra extension cable is good with just 1 meter. From what I gathered, connection is: Smart Mirror > Fakra Cable > LR64584 Cable > Camera with the cover. If I have Fakra cable, do I still need LR64584 cable? It looks like that's just short cable looks just like Fakra cable so I'm not sure if I need that LR64584 cable. Please let me know. Thanks again for welcoming. |
@isugoo
If I remember correctly, I had it connected mirror > LR64584 Repair Cable > Fakra cable > camera antenna. You “may” be able to skip purchasing the LR repair cable by installing a Fakra cable with the correct ends. Not being an expert on Fakra connections, I deferred to the cables suggested by @mmbanf (Marco) |
Thanks for quick reply.
Most of UK retrofit kit sites have only one cable showing so I think they didn't use it but to be safe, I may need to get it. Thanks for your help! |
