Home > Puma (Tdci) > Alarm going off intermittently
YB64RUU2015
Hi I have a 2015 Defender and the alarm has started going off randomly usually at 12-3AM. The alarm just goes off but lights come on. Can’t turn it off in the end I took the positive lead off the battery. I tried locking it with the key but alarm went off again 30 minutes later. My neighbours are pretty tolerant but after the third night of doing this im pushing it.
Can anybody advise me on how to fix it or disable the alarm until I can get a ghost or scorpion fitted.
Many thanks
Mike
Post #1055357 22nd Dec 2024 5:33pm
revd
take care, some ner-do-well may be waiting for you to disable the alarm
Post #1055358 22nd Dec 2024 5:35pm
Dinnu
Does it start ok in the morning? As it could also be the battery voltage dropping too low, and the battery backup sounder BBUS would trigger. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1055361 22nd Dec 2024 6:14pm
YB64RUU2015
I thought initially it was someone messing with it but it’s blocked in by other cars and no lights going off just the alarm sounds and goes on and off for about 5 minutes. Didn’t disable when I took the negative cable off but stopped when I removed positive terminal
Post #1055362 22nd Dec 2024 6:39pm
What voltage is it sitting at, at rest? It could be dipping below the threshold that it likes to see. WeWillWin🇬🇧🇺🇸
Post #1055365 22nd Dec 2024 7:15pm
Ianh
Check your door and bonnet switches to see if they are working correctly and the terminals etc are not corroded.
Also have a look at your Alarm Locking Module (ALM) unit to see if it is wet and the two connectors going to it are properly seated. You can see the unit by removing the drivers footwell speaker and looking up at the bulkhead.
Post #1055366 22nd Dec 2024 7:20pm
YB64RUU2015
Thanks I need to check but relatively new battery and never any issues starting lights never dim.
Post #1055367 22nd Dec 2024 7:23pm
YB64RUU2015
Cheers that sounds like the most plausible as had some water leakage coming in to o the footwell.
Many thanks to all responses and will update when I find anything.
I am thinking of fitting a Scorpion after Christmas
Post #1055369 22nd Dec 2024 7:38pm
Ianh
Given its a new battery, make sure the cables are clamped well to the battery terminals. Easiest way is to loosen off the clamp and gently tap the clamp down on the terminal with a hammer and drift. Then torque up the clamp bolt.
Post #1055370 22nd Dec 2024 7:39pm
YB64RUU2015
Cheers first thing I did and we’re all tight and pushed into terminals.
Post #1055371 22nd Dec 2024 8:11pm
Is there any draught setting off the internal alarm? The volumetric sensor I think they call it?
Or it could be faulty if there is one fitted.
Failing that, a door or bonnet sensor is degraded that possibly the wind at night is jiggling it around, less likely if in closed garage though. WeWillWin🇬🇧🇺🇸
Post #1055401 23rd Dec 2024 11:42am
discomog
I have a 2015 90XS Station Wagon and I had exactly the same problem when it was a couple of years old. The only way I could stop it sounding was to disconnect the battery. Turned out to be the BBUS was faulty. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #1055405 23rd Dec 2024 12:14pm
YB64RUU2015
BBUS Battery Back up Sounder - anyone know if these are available as no one seems to stock them. Is it possible to remove them or do they cause an issue to stop the alarm going off randomly until I can get a replacement system
Post #1055409 23rd Dec 2024 12:42pm
Dinnu
I think your answer is in this thread: https://www.defender2.net/forum/topic65058-15.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1055423 23rd Dec 2024 2:03pm
YB64RUU2015
I did look at that thread but it doesn’t say it stops the issue by removing it or where you can get a new one other than LR who say not available
Post #1055425 23rd Dec 2024 2:07pm
