Home > Puma (Tdci) > Alarm going off intermittently |
revd Member Since: 20 Apr 2024 Location: England Posts: 132 |
take care, some ner-do-well may be waiting for you to disable the alarm
22nd Dec 2024 4:35pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3425 |
Does it start ok in the morning? As it could also be the battery voltage dropping too low, and the battery backup sounder BBUS would trigger. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
22nd Dec 2024 5:14pm |
YB64RUU2015 Member Since: 25 Feb 2024 Location: Staffordshire Posts: 8 |
I thought initially it was someone messing with it but it’s blocked in by other cars and no lights going off just the alarm sounds and goes on and off for about 5 minutes. Didn’t disable when I took the negative cable off but stopped when I removed positive terminal
22nd Dec 2024 5:39pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
What voltage is it sitting at, at rest? It could be dipping below the threshold that it likes to see. No Guts, No Glory.
22nd Dec 2024 6:15pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2034 |
Check your door and bonnet switches to see if they are working correctly and the terminals etc are not corroded.
Also have a look at your Alarm Locking Module (ALM) unit to see if it is wet and the two connectors going to it are properly seated. You can see the unit by removing the drivers footwell speaker and looking up at the bulkhead. |
22nd Dec 2024 6:20pm |
Thanks I need to check but relatively new battery and never any issues starting lights never dim.
22nd Dec 2024 6:23pm |
Cheers that sounds like the most plausible as had some water leakage coming in to o the footwell. Many thanks to all responses and will update when I find anything. I am thinking of fitting a Scorpion after Christmas |
22nd Dec 2024 6:38pm |
Given its a new battery, make sure the cables are clamped well to the battery terminals. Easiest way is to loosen off the clamp and gently tap the clamp down on the terminal with a hammer and drift. Then torque up the clamp bolt.
22nd Dec 2024 6:39pm |
Cheers first thing I did and we’re all tight and pushed into terminals.
22nd Dec 2024 7:11pm |
Is there any draught setting off the internal alarm? The volumetric sensor I think they call it?
Or it could be faulty if there is one fitted. Failing that, a door or bonnet sensor is degraded that possibly the wind at night is jiggling it around, less likely if in closed garage though. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
23rd Dec 2024 10:42am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2530 |
I have a 2015 90XS Station Wagon and I had exactly the same problem when it was a couple of years old. The only way I could stop it sounding was to disconnect the battery. Turned out to be the BBUS was faulty. Defender 90XS SW
23rd Dec 2024 11:14am |
BBUS Battery Back up Sounder - anyone know if these are available as no one seems to stock them. Is it possible to remove them or do they cause an issue to stop the alarm going off randomly until I can get a replacement system
23rd Dec 2024 11:42am |
I think your answer is in this thread: https://www.defender2.net/forum/topic65058-15.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
23rd Dec 2024 1:03pm |
I did look at that thread but it doesn’t say it stops the issue by removing it or where you can get a new one other than LR who say not available
23rd Dec 2024 1:07pm |
