Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 105 of 105 <123 ... 103104105
Colin68
[quote="northeye"]Hello.
I've found new activations after upgrading firmware to B3906.
Soft Buttons on sidebar interface. (see hunters "DEFENDER PIVI PRO MY25 INTERFACE" activation)
    * MultiCAN-882 Sidebar Controls
    from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i"
    * MultiCAN-892 SideBar Climate
    from "Climate Icon on Side Bar Not Available" to "Climate Icon on SIde Bar Available - FICP Replacement"
    * MultiCAN-896 ReCircle Soft Button
    from "Not Fitted" to "Soft Button Fitted with timed and latched logic"
    * MultiCAN-897 Max AC Soft Button
    from "Not Fitted" to "Soft Button Fitted"
    * MultiCAN-897 Max Defrost Soft Button
    * MultiCAN-897 AC OnOff Soft Button
    * MultiCAN-897 Auto Climate Soft Button
    from "Front AUTO Climate Soft Button Not Fitted" to "Front AUTO Climate Soft Button Fitted"
    * MultiCAN-898 Front Htd Screen Soft Button
    * MultiCAN-898 Rear Htd Screen Soft Button
    * MultiCAN-894 Volume Soft Keys
    from "Not Fitted" to "Audio Volume Soft Keys pattern 1"
Volume button has been appeared on sidebar but unfortunately it does not work correctly for me.
Shortcut panel of Home screen is contained with this activation, maybe.
If you leave multiCAN 894 VOLUME SOFT KEYS AS NOT FITTED it works!
Post #1054722 15th Dec 2024 10:54am
Colin68
Post #1054723 15th Dec 2024 10:54am
mmbanf
Italy
hello and thanks for the information,
I tried on defender 2021 but had no luck, has anyone enabled the functions on this year of car? thanks
Marco Thumbs Up
Post #1054729 15th Dec 2024 11:55am
Ozzboz
United Kingdom 2005 Defender 90 300 Tdi SV 90 Auto Caprice
Battery drain issue following some CCF changes
Hi,
Thank you for all the great info in this forum thread. This is by far the biggest source of Gap iidTool information I’ve come across
Because of your help, I’ve been able to enable the following features on my 2021 Velar HSE R-Dynamic (I know this is not a Velar forum).
Park assist
ATPC
Auto Terrain Response
Configurable dynamics
I also played with 205 - racing subbrand Splash screen to add the RDynamic logo to the speed dials.
This was all done over about a week. Somewhere along the process and maybe a coincidence, but I developed severe battery drain. Two days of standing on the drive, the car would lose all battery power.
I replaced the battery, it was 4 years old anyway. New battery, same issue. Has anyone else come across this? Could it be caused by CCF changes made with the Gap G4 tool?
I have no permanent faults showing other than the below - Is this standard when changing the CCF as it seems to relate to a CCF configuration mismatch?
U2101-00 (2A) Control Module Configuration Incompatible - no sub type information
Thanks for any input you can offer
Mark. [/code]
Post #1055130 19th Dec 2024 4:15pm
Defendit..
Netherlands
@ozzboz
Very important to charge your battery full before attempting CCF changes.
After changing charging also or a good trip of half an hour minimum.
I'am much more carefull now especially when there is also new SOTA knocking on the door.
Before you know your battery is toast No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1055139 19th Dec 2024 5:53pm
mmbanf
Italy
hi Ozzboz,
ccf file modifications can change the vehicle's CAN networks and cause anomalies,
what happens? the vehicle does not go into sleep mode, it always stays awake.
as Defendit says, a problem can certainly also be the battery discharge, on long encodings it is always better to use a diagnostic power supply.
You can check if the vehicle is sleeping, looking if the red lighting of the hazard button goes off when you close the car after about 10 minutes.
I don't understand your dtc error, you did not indicate the original ecu.
Post #1055150 19th Dec 2024 7:08pm
mmbanf
Italy
Shocked red hazard button on defender, velar I don't know.....
Post #1055151 19th Dec 2024 7:31pm
northeye
Japan
I tried that on MY23.5 but no luck.
I believe that it requires MY24 or above, since my friend has succeeded on MY24.
Post #1055293 21st Dec 2024 3:23pm
Colin68
Yes mine isMY25
Post #1055324 22nd Dec 2024 10:03am
