Home > Td5 > Defender 15p not starting
Page 2 of 3 <123>
Dr Phibes
Australia
So the pressure should stay high after the pump stops, and the pump incorporates a non return valve?
It’s bafflingly hard to find a clear answer to this on any forum! There is discussion here but inconclusive: https://www.landyzone.co.uk/land-rover/td5...em.161412/
I can’t see how the pressure regulator would help- it just discharges fuel if over pressure.
And the NRV in the filter head is optional and only seems to stop fuel flowing into the return from the engine assembly.
Post #1054274 9th Dec 2024 9:34pm
Dr Phibes
Australia
Bump. Still struggling after replacing multiple parts. I also added a pressure gauge at the temp sensor port.
Would be really helpful if someone can confirm pressure should stay high. Or at least non zero…
Post #1055254 21st Dec 2024 12:23am
revd
Did you put additive in the tank because you were having starting/running issues?
The job is a pain but I would still change the pump.
I had an Elise that would crank but not start - it was the pump
My old Td5 went from first flick of the key to multiple attempts- it was the pump
Yours might not be the pump but you need to eliminate it as a possible cause
Post #1055260 21st Dec 2024 8:51am
Dr Phibes
Australia
I put additive in because I did with another vehicle and it made an appreciable difference. I bought the defender recently and am working my way through it so thought I would give it a shot.
I have put a new VDO pump in. The old pump was probably original but worked fine. Both reliably output 4.5 bar at the fuel regulator.
I also replaced the main relay and fuel pump relay with new narva relays.
I have checked that fuel is flowing properly in all of the lines.
The only other things I can think of are injector seals, the ECU not firing the injectors, some weird head blockage, or the fact the air bleed valve is Censored fuel through per my other thread at https://www.defender2.net/forum/post1055263.html#1055263
The fact it doesn’t hold pressure seems strange. If someone has actually put a fuel pressure gauge on and observed normal behaviour it would be very helpful to know.
Post #1055264 21st Dec 2024 9:10am
A.Rubio
Spain
Have you checked the impact switch located in the engine compartment near the coolant reservoir to make sure it is not tripped?.
Saludos y suerte
Post #1055296 21st Dec 2024 5:56pm
Dr Phibes
Australia
Yes I did. When the inertia switch triggers it disables the fuel pump completely. So it won’t even prime.
Post #1055310 21st Dec 2024 9:09pm
landy andy
I had similar issues with a Td5 disco that I worked on. Couldn’t get my head around what the problem was, and to be honest still can’t. In the end I squirted brake cleaner (lightly) into air intake. It ran on the brake cleaner and has since been fine running and starting for probably two years. Still confused
Post #1055315 22nd Dec 2024 8:24am
Dr Phibes
Australia
Perhaps you had trapped air that cleared on running? Had you been working on the fuel system?
Mine gets ignition on starting fluid but dies immediately as there’s no fuel…
Post #1055317 22nd Dec 2024 8:54am
landy andy
Nope. No fuel work done till issue, then swapped pump. Still the same. Swapped pump again each time testing pressure. Then brake cleaner away it went.
But not a solution for you then.
Post #1055322 22nd Dec 2024 10:46am
Dr Phibes
Australia
When you tested pressure, did it hold pressure after the pump primed?
Post #1055325 22nd Dec 2024 11:09am
landy andy
Sorry can’t remember Embarassed Embarassed
Post #1055350 22nd Dec 2024 5:00pm
A.Rubio
Spain
Good morning, stop by the Land Rover Argentina club and in the Td5 section there are many comments about fuel pressure, I seem to remember that "Lucas "made some comments on this topic
Post #1055654 26th Dec 2024 11:18am
Dr Phibes
Australia
Thanks. This one?
https://www-landroverclub-com-ar.translate...r_pto=wapp
I have put a pressure gauge in the fuel temperature sensor port using a t piece.
Convinced the britpart filter is a dud.
I have an allmakes bleed valve and a new billet filter head coming. Will anneal washers to be on the safe side. I will test with an AC vacuum pump before reinstalling.
Also I put an ebay kayak hatch in for pump access (I have a 127L long ranger tank - hence non standard)
Post #1055657 26th Dec 2024 1:30pm
landy andy
Been playing with mates Td5 that he is having trouble with, and pressure drops of immediately after engine switch off, and believe this is normal.
Post #1056011 31st Dec 2024 9:28pm
Dr Phibes
Australia
Thanks.
I’m coming to the same conclusion. I have also noticed that when cranking pressure shoots back up on the FPR.
Symptoms seem like air lock at head.
Currently replacing injector washers and seals. Old washers and injector tips had a lot of carbon.
Post #1056014 31st Dec 2024 9:41pm
Page 2 of 3 <123>
