![]() | Home > Td5 > Defender 15p not starting |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Does it start every time after a fuel prime?
If yes then possibly injector seals. If you don’t hear the relay each time you turn on the ignition check terminals on fuel pump relay. |
Dr Phibes Member Since: 24 Apr 2024 Location: Melbourne Posts: 71 ![]() ![]() |
It isn't starting at all, no ignition whatsoever. It usually only primes when I trigger a purge. Otherwise only every tenth attempt or so...
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 226 ![]() ![]() ![]() |
Pretty sure the Nanocom lets you test injectors? I.e. you can 'fire' them remotely, listening for a click? Would be good to confirm that there's communication from ECU to injectors.
You could try a bit of easy start, will just confirm that you have compression and timing, and will then pinpoint that the issue is fuel (supply or injection). 1990 Defender 110 200TDI Camper - now converted to Td5 power |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1230 ![]() ![]() ![]() |
If you have priming issues I suggest you look at that again. Fuel pump or relay can be going out. I had an issue where the engine was running but after I disconnected the fuel line I could not get it to prime again.
Pump was running but not pumping. Was pretty clear as with the fuel lines disconnected at the cooler and the pump priming there was just a dribble coming out. Had to do the ritual and chop the hole in the rear floor to change the pump. Made a nice hatch that should have been there from the start. After pump change there was as strong flow that filled up a water bottle in no time. |
Thanks. Those are good suggestions.
I have tested the injectors, they are OK according to the nanocom. I also changed the crank sensor. The cranking RPM doesn’t get over 210, I have read it needs to be over 300? Denso starter on order. I will try easy start and cutting the floor to get to the pump - was always going to do that anyway. Has anyone tried to replace the pump motor? I will probably shell out for a VDO one but would like to keep a spare. |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
With Nanocom check, it the engine ECU is not imobilized. It is in the last menu.
If not, there could be problem with in tank fuel pump. Before remowing it from tank, you can measure supply current to pump, measuring at the fuse. And also measure fuel pressure, it shoulb be 4 Bar. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Thanks, will do.
However I have successfully removed the 10AS and modified the ECU. Have done 100s of Ks since. And it wouldn’t crank if immobilised. On a related point I pushed the rollover inertia switch and could have sworn it clicked! Made no difference to starting though. My gut feel is it’s fuelling; will explore that next. |
I have overhauled the fuel filter head. The non return valve was stuck open and the air purge valve was blocked.
I replaced the crank sensor as the old one looked cooked. But worked fine. The pump seems Ok. I have connected a pressure gauge to the pressure regulator (in the fuel temperature port) and when running a purge I get a steady 4 bar. BUT the pressure drops to zero as soon as the pump stops. Does that suggest a failed return valve? |
I’m beginning to wonder if the non return valve is in the wrong position… I reassembled it as it was and as some forums suggest. As shown… on front inside.
![]() Click image to enlarge But I have seen other people suggesting back inside and this seems to make more sense as that’s feeding from the tank rather than the cooler? |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 814 ![]() ![]() ![]() |
![]() Click image to enlarge Does this help? |
The claim is that it goes on line 12 (as it was originally). I don’t understand the logic of it unless the duckbill stays closed when pressure is withdrawn to stop the fuel from that line and all upstream draining… this guy seems adamant that is correct but doesn’t explain why…
Update…
New battery. Also earthed ECU to battery. Although had low resistance to earth. Assuming that pressure is supposed to drop after priming, I think pump is fine. Also put more diesel in tank. Although still not full as using jerry cans. Tested everything I could think of with nanocom. No issues apparent. Questions: Given that I put fuel system cleaner through recently could it be junk blocking the tiny filter behind the pressure regulator, or the injectors? RPMs not getting over 220. Starter motor compromised? I notice while cranking it takes about 5s for the RPMs to show on the nanocom. Noisy signal from starter? When fitting a new crank sensor I noticed the old one had no o-ring. It was really hard to get the new one in with an o-ring. It sits out about 1mm. Problem? If the nanocom is able to trigger the injectors and I am seeing the cylinder values change while cranking can I assume the ecu is firing them? If there was an injector leak or blockage wouldn’t it at least start? Thanks! |
I dumped a lot of starter fluid in and it ran briefly.
After taking the fuel pressure regulator apart, and checking the mesh filter (which was clean), something blindingly obvious struck me… The problem is that after priming the fuel is draining back into the tank? Because the pressure is returning to zero as soon as the pump switches off. Surely that shouldn’t happen? |
revd Member Since: 20 Apr 2024 Location: England Posts: 227 ![]() ![]() |
I would drop the tank, check for contamination and swap out the pump
