![]() | Home > Td5 > Defender 15p not starting |
revd Member Since: 20 Apr 2024 Location: England Posts: 236 ![]() ![]() |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 818 ![]() ![]() ![]() |
Glad you stuck with it... Back on the road 👍🏼
Dr Phibes Member Since: 24 Apr 2024 Location: Melbourne Posts: 71 ![]() ![]() |
Actually... I celebrated too soon. It ran and then I tried again and failed. According to the Nanocom the injector codes are being lost. I am going to start a separate thread, and cross-post on the nanocom forum... I have modded the ECU, may be the root cause.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
What fuel additive did you run????
I have traced the problem to ECU and immobiliser issues, so the additive wasn’t a factor. But it was this: https://www.nulon.com.au/products/additive...reme-clean (I am in Australia).
So it was immobilising… turns out the ECU won’t fire the injectors if immobilised. I took my new ECU and used the excellent mems3 app to set the immo off. I must have
