Home > In Car Electronics > Nakatanenga DAB antenna |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1433 |
An earlier post identified the same problem with the Nak splitter,
13th Dec 2024 2:32pm |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 370 |
Thank you,
I must have missed that reading through the posts. I’ll try a different splitter like that. Cheers. 2006 Defender Double Cab- Zambezi Silver |
13th Dec 2024 2:42pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
You have to turn the aerial power off on the head unit. And then you power your Nak loom. Fitted mine a few weeks ago. Same headunit as you 👍🏻 |
13th Dec 2024 5:16pm |
Thanks for that Landy Andy, eventually found that option and once I turned it all was well.
Cheers 2006 Defender Double Cab- Zambezi Silver |
18th Dec 2024 2:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20498 |
Yes, there is a setting for that, which is a bit annoying as you can easily chose the wrong one by accident.
These Antennas make a good Xmas present if you don’t already have one, I’m very pleased with it. I’ve had one a few years now, works well and is robust. Ideal that it is always there, so it doesn’t need putting up and also life proof for off road, won’t get damaged green laning etc. If you want the DAB on, you can just put it on whenever. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Dec 2024 5:25pm |
