Home > In Car Electronics > The definitive Defender ICE thread
Page 70 of 71 <123 ... 697071>
Looks great. Thumbs Up
If you have a glove box you can use a USB socket up in there on the RHS vertical surface as well, you get a good GPS signal there too.
Very Happy WeWillWin🇬🇧🇺🇸
Post #1052989 26th Nov 2024 11:31am
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Thanks!
Glovebox is on the Christmas list Wink 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1052995 26th Nov 2024 11:46am
JW51MAT
Matt110 wrote:
That's more than enough money.
Head unit, single DIN, lots around, Bluetooth is the only real feature required. £120-150.
A pair of 4" component speakers for the front. I understand the Focal thoughts... but in my opinion they really don't have to be Focal. Yes focal are great but with a £500 system you'll loose most of the budget buying them to little avail when the rest of the kit isn't worth the thousands needed to drive them to their full potential. A balanced system can be had without spending 2/3 the budget on a single pair of front speakers which will deliver clarity but zero bass... Anyway, £60. Ish.
A set of larger component speakers for the rear, £100.
Then add a fairly small, sensible, 8" sealed sub and amplifier, or a reasonable underseat sub, though I've little experience of the latter personally, packages can be had for about £150. Or buy an amplified bass box, again fairly small. Most car audio websites run deals and package deals to this end.
You should also upgrade the wiring to use much better speaker wire so chuck in £50 to buy that so the speakers can actually be driven effectively.
Will be transformed, fairly well balanced in terms of sound, and inside budget I'd expect.
The key is she is happy to use phone for visuals, so "all" you need is a reasonable single din head unit, and you're not putting countless budget into fascias etc and double din head units which are lovely but won't change your sound quality at all.
(I'd love a double din... Just thinking of your want to improve sound, not visual).
Hi Matt,
I have finally decided after much badgering by my daughter to take on this project. I think the following items will satisfy her requirements and allow me to complete the task. why are the 4" speakers so expensive compared to the 5.25" or am I missing something?
Head unit: Alpine UTE-204DAB £150
Sub: Alpine SWE-1200 8 inch Powered Subwoofer Box £165
Front speakers: ALPINE 280W TOTAL 2WAY 4-INCH 10cm CAR DOOR COMPONENT SPEAKERS TWEETERS S2-S40C £120
Rear speakers: ALPINE SXE-1350S 5-1/4"(13CM) COMPONENT 2-WAY SPEAKER £50
Aerial: ALPINE AN-DAB1 - Glass Mount DAB Digital Car Radio Aerial Antenna £15
Harness: CT20BM02 Land Rover Defender 2001> Wiring Harness Adaptor ISO Lead £10
Cables: no idea what I'm likely to require.
Post #1054330 10th Dec 2024 12:41pm
DSC-off
I found stick on DAB antennas to be useless when there isn't a really good signal.
A powered splitter isn't expensive and works much better connected to the original wing antenna.
Connects2 make 2 types, with different DAB connections SMA or SMB, make sure you get the correct one for the headunit.
Those Alpine speakers listed don't seem to include grilles, they're intended to fit behind trim panels.
You might be better off picking a set that has grilles included and all work together. Thumbs Up
Post #1054349 10th Dec 2024 4:03pm
Yes, those glass mount DAB Antennas aren’t great.
You have two main options, a DAB splitter with the factory antenna.
Or a more robust, possibly better performing option?
The Nakatanenga flexi which comes with a DAB splitter. WeWillWin🇬🇧🇺🇸
Post #1054359 10th Dec 2024 7:08pm
JW51MAT
So after a little more digging and advise from above I will look at a a powered splitter and I think I will look to fit The ALPINE SXE-1350S 5-1/4"(13CM) COMPONENT 2-WAY SPEAKER to the front also.
Post #1054416 11th Dec 2024 12:24pm
DSC-off
Hi,
The Alpine SXE-1350S don't come with grilles either.
They do seem reasonable value for money though and have good sensitivity (90 db/w/m) so should sound OK in a non amplified system.
Just budget for additional grilles and be sure they fit the Alpine woofers.
I've fitted 5 1/4" speakers to the dash in both Td5 and Puma Defenders. It is more work than just dropping in 4" speakers.
Be sure the depth behind the panel will clear magnet and basket of whatever you intend to fit.
Remove the existing speakers at BOTH sides of the dash, measure and check.
Heater ducts, wiper motors and dash construction can scupper plans or cause more work.
There seems to be a lack of availability and stock of 4" component speaker sets with grilles these days.
That's probably a reflection of where modern cars have gone and what most people are fitting these days.
Post #1054434 11th Dec 2024 2:17pm
JW51MAT
Hi,
Is it really worth going component speakers with tweeters v's coaxial it's not as if it's a FFRR, it's noisy as hell even with the sound proofing?
Post #1054574 13th Dec 2024 11:52am
Matt110
Yes, hands down. Makes a difference. Especially if you have a puma and naturally mount those tweeters high up in the dash as designed, or if you're pre-puma and can mount them on the top of the dash in pods. You'll find the sound clearer, speach easier to hear. It's not so much the separation that helps, its the fact that defenders always point the speakers at the floor, which isn't such a great plan for high frequencies. So separating them physically allows you to get them to where you can hear them.
Post #1054586 13th Dec 2024 1:27pm
TexasRover
JW51MAT wrote:
Hi,
While yes having tweeters on top makes sound clearer and voices easier to understand, I don't think you get much benefit from buying higher spec (more expensive) equipment. They need to be decent wattage etc but it's not exactly a high fidelity environment a Defender on the move.
Post #1054588 13th Dec 2024 2:18pm
Matt110
Agree with that. As long as they're component speakers and half decent you're going to get a sensible audio quality for an aluminium box with about as many sonic variances as a washing machine doing a spin cycle on a cutlery drawer.
Post #1054589 13th Dec 2024 2:28pm
DSC-off
JW51MAT wrote:
Hi,
Just my personal opinions, we all put a different value on everything, and the effort to achieve it. Very Happy
Any good quality, 4" 2way coaxial speakers will make a massive difference over the standard factory fit ones. Especially as you plan to fit a sub too, 4" will be lacking without it. This might do everything you want to achieve.
If you can be bothered, upgrading to 5 1/4" speakers will improve the bass. Either with or without a sub, as they work above the sub-bass frequencies. You might not think this is necessary or worth the hassle.
Coaxial or component?
My opinion, good quality coaxials can (do) sound very good. A high sensitivity speaker, say 88 to 91db, will work well powered just by the headunit. Even top brands make coaxials, some are very expensive.
Rear channels.
All the sound is projected forward, at the back of the driver's head. Coaxials are fine for this. A separate rear tweeter isn’t going to build a soundstage INFRONT of the listener.
As examples of rear coaxials, I've got Focal PC130 (5") in my 110 and Pioneer TS-A1081F (4") in the rear of another car.
Front channels.
A lot of people would be quite happy with coaxials in the lower dash.
They would however notice a difference with component tweeters on top of the dash, lifting the sound to windscreen level, the optimal listening position, instead of being down at knee level.
I have Focal component speakers in the front of both my vehicles, but wouldn’t say you have to do this just because I have. (I'd probably not use Focals again either, at current prices Shocked )
Your daughter's 90 seems to be a run around hack for horse interests. (Sorry if it's not and I've miss understood)
With that in mind, I'd fit a simple system without going over the top.
If 4" coaxials and a sub aren't enough, it's not a massive change to swap the fronts for 2way components later.
Lots in there, but hope it helps with the decision. Thumbs Up
To add, £50 to £100 per pair would be my budget for coaxials.
Post #1054594 13th Dec 2024 3:09pm
Fataitch
United Kingdom 2010 Defender 110 Puma 2.4 PU Portofino Red
5.25 in the front will definitely make a difference over 4”, but it is a little extra work.
I used these to simplify fitting a little,
https://www.dynamicsounds.co.uk/ct25uv16-u...ptors.html
reduced the amount needed to cut away and to try and angle the sound a little further forward (but they’re for woofers, so not really necessary).
If positioned well, they will fit with the raised part of the lower dash that the std speakers fix to, almost looking like they’re meant to be there.
On the passenger side (Puma), one of the plastic heater pipes will probably get in the way a little - I used a little heat and gentle persuasion to move it aside a little.
I also used the silicon speaker baffles to help retain some of the lower frequency sounds on the woofers.
One last thing, I didn’t realise how much car HiFi has come on in recent years - my head unit (cheap KENWOOD) has a built in 3 way active crossover that you can tweak to suit - meaning each component has it’s own channel (I’m also running a Cerwin Vega under seat sub).
Not quite finished installation yet but nearly done
Post #1055230 20th Dec 2024 6:30pm
Just beware that it can get very expensive very fast. Laughing WeWillWin🇬🇧🇺🇸
Post #1055241 20th Dec 2024 7:28pm
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Stinger heigh 10 Reversing Camera Trigger
Hi everyone;
For those who have fitted the Stinger Heigh 10 unit to their Defender, could you please advise which line you attached the reverse camera trigger (power from the reverse light) to on the units looms? The instructions are contradicting them selves, I’m thinking it’s the green line with a white trace, but the instructions say the purple with white trace, even though it’s labeled differently.
I haven't run the line from the reverse lamp yet, and realise I could just connect to either and see which works, but would like to know what others have done. Damn theres an excess of cables from the speaker loom. I’m considering cutting them off as they’re in excess of my needs and space behind the stereo in my 110 Puma is pretty scarce.
Thanks for any info, I appreiciate it.
Ken 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #1058311 23rd Jan 2025 9:12am
