Home > Wheels & Tyres (L663) > Tyres in I663 275/60/20
ruben
Spain
Hi to all!
Does anyone know if it is possible to install it on I663 110 23 MY I6 D MHEV without modifying anything in the wheel arches or installing spacers?
Thanks in advance!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1054149 8th Dec 2024 1:11pm
BadgerWaz
I fiited this size and they're perfect. They fill the arches like the factory tyres should have. I have fitted the genuine factory Land Rover mudflaps and wheel arch extensions prior to having the new tyres fitted and they all compliment each other well.
No wheel-spacers needed.
No rubbing.
Speedo is now correct (UK standard settings).
The gearing appears to be unaffected too.
Post #1054152 8th Dec 2024 1:55pm
ruben
Spain
Thank you very much for your kind and prompt response!! Defender 110 SE I6 D250 23MY
Post #1054154 8th Dec 2024 2:18pm
91dm
Ireland
That does look very good on 275's BadgerWaz
Post #1054169 8th Dec 2024 4:30pm
Crazymind
Looking good! No rubbing off road or at full lock?
Post #1054209 8th Dec 2024 9:42pm
BadgerWaz
No not at all. The BFG's have quite a hard tread but with the extra inch height I'm sure it'll even itself out.
I think the 110 looks juicy now.
Post #1054216 8th Dec 2024 11:46pm
F-Typical
No rubbing.
When you say the speedo is now correct, what was the problem before and what tyres were you using?
TIA.
Post #1054236 9th Dec 2024 10:41am
BadgerWaz
That it now no longer under-reads. Manufacturers set these below the actual speed shown in the cluster (a set tolerance) to accomodate different size wheels/tyres/pressures so you're never actually driving at 60 when the speedo says it's 60 (more like 57).
You can correct this using IIDG4 but I never bothered.
With my larger tyres my speedo now matches gps perfectly, so 30 is 30 (not 27.5 mph) etc.
Sheep
255/60/20 factory size previously.
Post #1054291 9th Dec 2024 10:21pm
F-Typical
Ah - ECE Regulation 39.
Was wondering if there was a specific JLR-related problem...
Post #1054293 9th Dec 2024 10:53pm
Eric Caterpillar
I really like the look of that setup, looks mean, but in a purposeful way.
Interestingly, you said that the 275/60/20 doesn't rub anywhere, I found a post somewhere else saying that it did. I am looking for getting a second wheel + tyre set for any winter/off road driving and weighing in all the tyre setups:
255/60/20
275/55/20
and now also
275/60/20
Depending on a tyre availability.
Post #1054327 10th Dec 2024 10:39am
BadgerWaz
Mine don't rub on anything.
8.5" wheel diameter.
Used offroad.
Coil springs.
Post #1054393 10th Dec 2024 11:02pm
