Home > Wheels & Tyres (L663) > Tyres in I663 275/60/20 |
BadgerWaz Member Since: 15 Jul 2024 Location: Linconshire Posts: 96 |
I fiited this size and they're perfect. They fill the arches like the factory tyres should have. I have fitted the genuine factory Land Rover mudflaps and wheel arch extensions prior to having the new tyres fitted and they all compliment each other well.
Click image to enlarge No wheel-spacers needed. No rubbing. Speedo is now correct (UK standard settings). The gearing appears to be unaffected too. Click image to enlarge Click image to enlarge |
8th Dec 2024 1:55pm |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 233 |
Thank you very much for your kind and prompt response!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
8th Dec 2024 2:18pm |
91dm Member Since: 26 Feb 2024 Location: Ireland Posts: 35 |
That does look very good on 275's BadgerWaz
8th Dec 2024 4:30pm |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 208 |
Looking good! No rubbing off road or at full lock?
8th Dec 2024 9:42pm |
No not at all. The BFG's have quite a hard tread but with the extra inch height I'm sure it'll even itself out.
I think the 110 looks juicy now. Last edited by BadgerWaz on 27th Dec 2024 1:00am. Edited 1 time in total |
8th Dec 2024 11:46pm |
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 49 |
When you say the speedo is now correct, what was the problem before and what tyres were you using? TIA. |
9th Dec 2024 10:41am |
That it now no longer under-reads. Manufacturers set these below the actual speed shown in the cluster (a set tolerance) to accomodate different size wheels/tyres/pressures so you're never actually driving at 60 when the speedo says it's 60 (more like 57).
You can correct this using IIDG4 but I never bothered. With my larger tyres my speedo now matches gps perfectly, so 30 is 30 (not 27.5 mph) etc. 255/60/20 factory size previously. |
9th Dec 2024 10:21pm |
Ah - ECE Regulation 39.
Was wondering if there was a specific JLR-related problem... |
9th Dec 2024 10:53pm |
Eric Caterpillar Member Since: 17 Jun 2024 Location: West of Scotland Posts: 65 |
I really like the look of that setup, looks mean, but in a purposeful way.
Interestingly, you said that the 275/60/20 doesn't rub anywhere, I found a post somewhere else saying that it did. I am looking for getting a second wheel + tyre set for any winter/off road driving and weighing in all the tyre setups: 255/60/20 275/55/20 and now also 275/60/20 Depending on a tyre availability. |
10th Dec 2024 10:39am |
Mine don't rub on anything.
8.5" wheel diameter. Used offroad. Coil springs. |
10th Dec 2024 11:02pm |
