Home > Maintenance & Modifications > Soft top conversion
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
Soft top conversion
Changing my 90 TD5 SW to a soft top.
Got the HD hoop kit, mohair cover, etc.
Just looking at the interior now.
What interior light is fitted as standard on a soft top? Is there one?
Assume sun visors just bolt onto the top of the windscreen frame?
Any advice or photos appreciated. 2001 90 TD5 Soft Top - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1051972 17th Nov 2024 10:48am
Welshsurferdude
Wales
theres no interior lights on a soft top, you'd have to fabricate a mount onto top of screen if u still want one
the sunvisors do bolt to top of screen 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #1051976 17th Nov 2024 11:25am
jst
I am looking for a roof, side panels and rear door I your selling. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1052024 17th Nov 2024 10:09pm
Litch
I bought this bracket from Protection & Performance, takes the standard light (which I fitted LED's to).
This photo dates from 2013 but I presume the bracket is still available as it was a top piece of kit.
 ONE LIFE, GET IT!
Post #1052181 19th Nov 2024 12:52pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
my interior light solutions.
Post #1053048 26th Nov 2024 9:53pm
Zed
Very neat solution. Where is that mirror from? WARNING.
Post #1053053 26th Nov 2024 10:13pm
ginjez
Mirror is from an MGF Thumbs Up
Post #1053079 27th Nov 2024 8:40am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Very nice, would you have a part number. was it hard to fit
Post #1053102 27th Nov 2024 1:59pm
Biscuits
Conversion was delayed, but has started in anger now. Today saw the roll hoops being test fitted.
Thanks for the interior light info, very usefull.
Anyone got a photo of the softtop windscreen top bar, without the hood fited? Trying to work out how it attaches. TIA 2001 90 TD5 Soft Top - Epsom Green
Post #1056812 9th Jan 2025 6:09pm
jst
it will only go one way with the bead for the hood along the front. have you offered it up? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1056847 9th Jan 2025 10:05pm
Biscuits
Bit more research and it looks like I have a bolt-down rail, rather than one with lever/hinges. So will need a socket to remove the hood when required.
Quote:
"The round front section has 4 grab handles which can be used to make the hood quick release or a sun roof option. This option is what we make as standard, so if you order the hood and frame this is the over screen type that you will usually get.
The flat front section has 6 bolts which is a more fixed option so has to be unbolted to be removed."
https://awttrimcentre.co.uk/shop/landrover...frame-set/
Might order the one with the levers, just so it's a bit easier. 2001 90 TD5 Soft Top - Epsom Green
Post #1056869 10th Jan 2025 10:58am
Biscuits
I've emailed P&P to see if they still make this bracket, looks like the perfect solution. 2001 90 TD5 Soft Top - Epsom Green
Post #1056873 10th Jan 2025 11:28am
Biscuits
Found one of these on eBay. Just need to figure out how to mount Shocked 2001 90 TD5 Soft Top - Epsom Green
Post #1057459 15th Jan 2025 5:30pm
Biscuits
Well, this is almost done now. Electrics to sort and I'm installing a TransK9 drawer in the back.
Swapped from 315 MT's to 285 AT's and still think it looks great.
Guys that have done the work have been brilliant, as anyone knows, nothing goes to plan or is straight forward on a Defender! https://alteredimagecoachworks.co.uk/ 2001 90 TD5 Soft Top - Epsom Green
Post #1059796 7th Feb 2025 1:11pm
