![]() | Home > Maintenance & Modifications > Soft top conversion |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2449 ![]() ![]() |
theres no interior lights on a soft top, you'd have to fabricate a mount onto top of screen if u still want one
the sunvisors do bolt to top of screen 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
I am looking for a roof, side panels and rear door I your selling. Cheers
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
I bought this bracket from Protection & Performance, takes the standard light (which I fitted LED's to).
This photo dates from 2013 but I presume the bracket is still available as it was a top piece of kit. ![]() Click image to enlarge ONE LIFE, GET IT! |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
my interior light solutions.
![]() Click image to enlarge ![]() Click image to enlarge |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3354 ![]() ![]() ![]() |
Very neat solution. Where is that mirror from? WARNING.
This post may contain sarcasm. |
Mirror is from an MGF
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 522 ![]() ![]() ![]() |
Very nice, would you have a part number. was it hard to fit
Biscuits Member Since: 27 Mar 2023 Location: Kent Posts: 71 ![]() ![]() ![]() |
Conversion was delayed, but has started in anger now. Today saw the roll hoops being test fitted.
![]() Click image to enlarge Thanks for the interior light info, very usefull. ![]() Click image to enlarge Anyone got a photo of the softtop windscreen top bar, without the hood fited? Trying to work out how it attaches. TIA 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
it will only go one way with the bead for the hood along the front. have you offered it up? Cheers
Bit more research and it looks like I have a bolt-down rail, rather than one with lever/hinges. So will need a socket to remove the hood when required.
https://awttrimcentre.co.uk/shop/landrover...frame-set/ Might order the one with the levers, just so it's a bit easier. 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
I've emailed P&P to see if they still make this bracket, looks like the perfect solution. 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
Found one of these on eBay. Just need to figure out how to mount ![]() 2024 90 D300 HSE X-Dyn HT - Santorini Black |
Well, this is almost done now. Electrics to sort and I'm installing a TransK9 drawer in the back.
![]() Click image to enlarge Swapped from 315 MT's to 285 AT's and still think it looks great. ![]() Click image to enlarge Guys that have done the work have been brilliant, as anyone knows, nothing goes to plan or is straight forward on a Defender! https://alteredimagecoachworks.co.uk/ 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
