![]() | Home > Puma (Tdci) > Thud noise |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Possibly upper or lower damper bushes, with looking at the bonnet though too. Chillin In The Backwoods🇬🇧🇺🇸
Vmax Member Since: 29 Apr 2023 Location: Europe Posts: 73 ![]() ![]() ![]() |
It sounds more likely thank you very much for your help.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
How old is the suspension? Could be many things. Need to get under there and have a look. Could be failed damper.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1139 ![]() ![]() ![]() |
Could be damper bushings (thanks for not calling a damper a shock btw). I find the bushings can fail quickly but are also very easy to install...
My defender year 2008 |
Thank you . |
If you get under, it’s worth checking the A frame bushes and ball joint too.
Though it’s central rear, it can seem like it’s coming from a direction it isn’t located and be deceptive. Though ball joint usually is a kind of knock, knock, knock on coasting off power approx 20 to 30mph when on and off light power you would notice it or on light potholes at lower speeds. It’s like to be damper bushes more though I think, look and feel for excess movement by pulling things around and or bounce suspension and look for movement. ![]() ⛽️🛢️⚙️🧰💪 |
I will checking it out tomorrow that been away from home work. First thing tomorrow morning.
Yes its damper bushes mite as well order the bushes of the rest.
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
I saw an ad for 25% off all Superpro recently. May be worth seeing what they have? Annoyingly I changed all mine in the summer. WARNING.
This post may contain sarcasm. |
Morning superpro thx l will check it out later if they can post it to Gibraltar.
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 827 ![]() ![]() ![]() |
if they cannot and will post to Spain, let me know and I can bring them across the border for you Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Gwyn Lewis has a deal on superpro stuff. I’d assume he would post for you.
https://gwynlewis4x4.co.uk/product/superpr...kit0043ck/ |
Thank you very much l will pm you. |
