Home > Puma (Tdci) > Thud noise
Vmax
Gibraltar 2008 Defender 110 Puma 2.4 SW Baltic Blue
Thud noise
I have on the front left hand side thud noise when l pass small pot holes.
Could it be l need new bushes?
Advice would be appreciated.
Post #1052199 19th Nov 2024 3:56pm
Possibly upper or lower damper bushes, with looking at the bonnet though too. WeWillWin🇬🇧🇺🇸
Post #1052224 19th Nov 2024 6:51pm
Vmax
It sounds more likely thank you very much for your help.
Post #1052237 19th Nov 2024 9:00pm
landy andy
How old is the suspension? Could be many things. Need to get under there and have a look. Could be failed damper.
Post #1052241 19th Nov 2024 9:21pm
TexasRover
Could be damper bushings (thanks for not calling a damper a shock btw). I find the bushings can fail quickly but are also very easy to install...
Post #1052270 20th Nov 2024 7:05am
Vmax
My defender year 2008
Post #1052416 21st Nov 2024 2:29pm
Vmax
Thank you .
Post #1052417 21st Nov 2024 2:30pm
If you get under, it’s worth checking the A frame bushes and ball joint too.
Though it’s central rear, it can seem like it’s coming from a direction it isn’t located and be deceptive.
Though ball joint usually is a kind of knock, knock, knock on coasting off power approx 20 to 30mph when on and off light power you would notice it or on light potholes at lower speeds.
It’s like to be damper bushes more though I think, look and feel for excess movement by pulling things around and or bounce suspension and look for movement. Very Happy WeWillWin🇬🇧🇺🇸
Post #1052436 21st Nov 2024 5:25pm
Vmax
I will checking it out tomorrow that been away from home work. First thing tomorrow morning.
Post #1052572 22nd Nov 2024 11:34pm
Vmax
Yes its damper bushes mite as well order the bushes of the rest.
Post #1052835 25th Nov 2024 12:02am
Zed
I saw an ad for 25% off all Superpro recently. May be worth seeing what they have? Annoyingly I changed all mine in the summer. WARNING.
Post #1052839 25th Nov 2024 12:15am
Vmax
Morning superpro thx l will check it out later if they can post it to Gibraltar.
Post #1052846 25th Nov 2024 7:50am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
if they cannot and will post to Spain, let me know and I can bring them across the border for you Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1052880 25th Nov 2024 3:07pm
landy andy
Gwyn Lewis has a deal on superpro stuff. I’d assume he would post for you.
https://gwynlewis4x4.co.uk/product/superpr...kit0043ck/
Post #1052898 25th Nov 2024 4:30pm
Vmax
Thank you very much l will pm you.
Post #1052900 25th Nov 2024 4:57pm
