Home > Puma (Tdci) > Thud noise |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20342 |
Possibly upper or lower damper bushes, with looking at the bonnet though too. $W33T $0U7H3RN $UG4R
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
19th Nov 2024 5:51pm |
Vmax Member Since: 29 Apr 2023 Location: Europe Posts: 65 |
It sounds more likely thank you very much for your help.
19th Nov 2024 8:00pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
How old is the suspension? Could be many things. Need to get under there and have a look. Could be failed damper.
19th Nov 2024 8:21pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1048 |
Could be damper bushings (thanks for not calling a damper a shock btw). I find the bushings can fail quickly but are also very easy to install...
20th Nov 2024 6:05am |
My defender year 2008 |
21st Nov 2024 1:29pm |
Thank you . |
21st Nov 2024 1:30pm |
If you get under, itโs worth checking the A frame bushes and ball joint too.
Though itโs central rear, it can seem like itโs coming from a direction it isnโt located and be deceptive. Though ball joint usually is a kind of knock, knock, knock on coasting off power approx 20 to 30mph when on and off light power you would notice it or on light potholes at lower speeds. Itโs like to be damper bushes more though I think, look and feel for excess movement by pulling things around and or bounce suspension and look for movement. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
21st Nov 2024 4:25pm |
I will checking it out tomorrow that been away from home work. First thing tomorrow morning.
22nd Nov 2024 10:34pm |
Yes its damper bushes mite as well order the bushes of the rest.
24th Nov 2024 11:02pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3280 |
I saw an ad for 25% off all Superpro recently. May be worth seeing what they have? Annoyingly I changed all mine in the summer. WARNING.
This post may contain sarcasm. |
24th Nov 2024 11:15pm |
Morning superpro thx l will check it out later if they can post it to Gibraltar.
25th Nov 2024 6:50am |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 816 |
if they cannot and will post to Spain, let me know and I can bring them across the border for you Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
25th Nov 2024 2:07pm |
Gwyn Lewis has a deal on superpro stuff. Iโd assume he would post for you.
https://gwynlewis4x4.co.uk/product/superpr...kit0043ck/ |
25th Nov 2024 3:30pm |
