Home > Maintenance & Modifications > Defender TD5 6HP Auto Conversion
Page 1 of 3 123>
bankz5152
Hellloo,
Has anyone done a 6HP auto conversion on a Defender TD5 on here?
Be good to hear some feedback about how they run and perform.
Not overly interested in an M57 at this point.
Thanks Very Happy Instagram @defender_ventures
Empire Tuning - Agent
Post #1052310 20th Nov 2024 3:26pm
jst
6hp into a defender yes done it.
M57, understood, that's me out. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1052331 20th Nov 2024 7:38pm
bankz5152
Haha just not right now. I like my Td5 its 280hp, easy to work on and 550nm+ of torque so no slouch.
Just getting a bit tired of the R380, eventually need a new uprated box, clutch will need doing in maybe 30k as well. Modernish auto would be nice and paves the way for an M57 in the future. Instagram @defender_ventures
Post #1052336 20th Nov 2024 7:55pm
Mo Murphy
I know MW do a TD5 to 8hp but I don't think there's one to 6hp. At least that I've read of !
But I also have an M57 so that's me out too 😁
50 Shades of Pennine Grey
Post #1052341 20th Nov 2024 8:26pm
bankz5152
I believe they use the same bolt patterns, tbf not overly troubled what.
Dont discount yourselves id like to see the interior for some inspo Very Happy Instagram @defender_ventures
Post #1052351 20th Nov 2024 8:49pm
Mo Murphy
Post #1052359 20th Nov 2024 9:32pm
bankz5152
Oo thats tidy! That the ashcroft center? Instagram @defender_ventures
Post #1052361 20th Nov 2024 9:39pm
Zed
Sell a kidney and fit a Quaife sequential 6 speed . WARNING.
Post #1052363 20th Nov 2024 9:44pm
bankz5152
Tbf both probably end up similar prices! Laughing Instagram @defender_ventures
Post #1052365 20th Nov 2024 9:53pm
Zed
Actually joking aside, you’re probably right. Plus you would have to spend quite a bit more to make an m57 auto quicker than a tuned TD5 with sequential. It’s a no brainer, get that kidney on eBay! WARNING.
Post #1052369 20th Nov 2024 10:19pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Mo Murphy wrote:
What is that blue surround on the key Barrel Mo? 4.0 V8 Defender 90
My Instagram
Post #1052378 21st Nov 2024 7:20am
bankz5152
Xeng column lock. Block of cncd stainless around the key barrel. For extra security Instagram @defender_ventures
Post #1052379 21st Nov 2024 7:33am
AJC
i frequently think of doing an auto conversion to mine, but don't want to use a D2 auto box. i would consider an 8hp conversion myself
Post #1052387 21st Nov 2024 9:37am
jonny
I think the biggest issue is going to be interfacing with the ZF Transmission Controller - the aftermarket TCUs require inputs from the engine ECU on throttle opening / RPM / Load / speed etc in order to be able to determine the shift points, lockup etc - these normally come via CANBUS direct from the engine ECU.
As far as I know, the TD5 ECU doesn't speak 'normal' CANBUS, so you are going to have to hook these up somehow to get these into the TCU..
Post #1052388 21st Nov 2024 9:54am
Mo Murphy
Perhaps it would be easier to just remove the TD5 from the equation and fit an M57 instead ? Laughing Wink
Post #1052393 21st Nov 2024 10:14am
Page 1 of 3 123>
