Home > My Defender > What Did You Do In Your Defender Today |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10376 |
It's putting up a fight Pam
6th Dec 2011 4:57pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3144 |
Was that for street lighting (so far as I know you can only use SWA for that). I once had to pull in a few Ks of it - we used a lorry. Bloody rotten stuff to work with, much prefer ABC or conventional wire. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
6th Dec 2011 7:40pm |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
It's a mains run from a garage to the main house, 50m so the cable is heavy enough to withstand voltage drop I believe. It's still not in, a smaller core Economy 7 wire for the same run went in a breeze, I've taken alternative measures and gotten some heavier draw cord for this stuff, we kept snapping the nylon 110 Tdci Double Cab |
6th Dec 2011 7:56pm |
And yes it's an absolute **** to work with!! 110 Tdci Double Cab
6th Dec 2011 8:02pm |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 |
Well.... hmmm maybe... if the model is not mine |
6th Dec 2011 8:13pm |
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 |
What kind of front grille is that you have ? |
7th Dec 2011 11:11am |
It's the KBX (used to be LRX) Satin Black Premium, with the stainless mesh. http://www.kbxupgrades.co.uk/kbx-defender-...rounds.php Today dragged the trailer around with some celotex for a bit Click image to enlarge photo 3 by .:alx:., on Flickr 110 Tdci Double Cab Last edited by ay4alex on 7th Dec 2011 8:36pm. Edited 1 time in total |
7th Dec 2011 5:27pm |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
110 picked up. All fixed. For now... Defender 110XS SW gone... now VW California 180 4 Motion.
7th Dec 2011 7:45pm |
8th Dec 2011 5:00pm |
It could be a local thing but I'm pretty certain it was not permitted to use SWA as mains cable, certainly not something I have ever seen in my time on the board. It was only used on private underground street lighting networks. The sizing I understand, just not the SWA part, I think its something to do with the type of earthing that could be used (you can't use PME on SWA IIRC) Sorry for the off-topic everyone 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
8th Dec 2011 6:06pm |
SilverFox Member Since: 07 Dec 2011 Location: Crickhowell Posts: 12 |
Where did you get them? Got to say they look really nice!! |
8th Dec 2011 6:09pm |
Thanks for the insight, I'm honestly not sure, it's my dad's build and I believe that the SWA was specced by the electrician. The main fuse board is in the garage as it is closer to the pole, this SWA then takes the power underground to the house. 110 Tdci Double Cab |
8th Dec 2011 6:13pm |
Thanks, do you mean the grilles or the photos?! Thanks 110 Tdci Double Cab |
8th Dec 2011 6:14pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
I was told by an electrician that it should really be SWA running from my house to the shed, not the crappy cloth-covered stuff that's there now. Can't quite face digging all the concrete up to change it though |
8th Dec 2011 6:43pm |
