Home > Puma (Tdci) > TDCi heater control valve options
Page 8 of 9 <123456789>
bear100
where do i order or pre order one of these bad boys? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1048014 8th Oct 2024 6:07am
Ianh
As per the link in my earlier post. See below
Ianh wrote:
Ian of IRB developments ( member porny on here) has them for sale on his integrated 316 site. See https://www.integrated316.com/store/p/land...trol-valve
£306 inc vat plus £6 postage... I wonder if a big group buy could facilitate a decent discount.
Post #1048026 8th Oct 2024 9:42am
Vitesse
Really interesting thread. The IRB unit looks fantastic but I have chosen to test first using a new unit from Autodoc. The Fiat / Citroen part shown in the thread. Approx £28 delivered. My own valve is still in good shape after 97000 miles (amazingly) and given the ease of access I will eventually use this cheap part and cross my fingers. Thumbs Up 2015 90 XS Santorini Black
Post #1048207 10th Oct 2024 7:52am
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
La válvula es exactamente igual es la de Fiat Ducato, misma marca !!!
Post #1048227 10th Oct 2024 11:25am
Waka56
Germany
Do you guys do any bleeding after you change the valve? I saw somewhere that it was a 20 mins job, which would indicate a simple unplug the old one/plug the new one Shocked Making my Defender great again. (Or trying to at least xD)
Post #1048443 12th Oct 2024 9:19am
bear100
Just a simple top up and bleed through the bleed screw on the 90 bend 2016 Range Rover Autobiography 4.4 TDV8
Post #1048445 12th Oct 2024 9:25am
Vitesse
New valve arrived. Decided to fit it as part of the EGR replacement that is imminent
I will note the water bleed advice. Thumbs Up
Post #1048456 12th Oct 2024 10:35am
Naks
@vitesse is this a direct replacement? No mods needed?
Can you please provide the part number? thanks Thumbs Up --
Post #1049564 23rd Oct 2024 5:37pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
I have that identical valve, two actually. There are some issues. First, the range of travel is a bit longer than stock. You have to adjust the cable position to either fully close, or fully open. It won't do both. No big deal, it just takes a second to adjust.
Unfortunately the second issue is more problematic. It does fully seal when closed but not when open. This means some coolant is able to bypass the heater core. This gives the classic hot on one side, cold on the other symptom.
So, in summary, not a good choice for replacement.
Post #1049567 23rd Oct 2024 5:55pm
jbcollier
Here’s the reverse side of the packaging so you can see the part number.
Post #1049598 23rd Oct 2024 11:18pm
Vitesse
Thanks for the heads up. I will check my valve and see if it has the same issue Thumbs Up 2015 90 XS Santorini Black
Post #1049630 24th Oct 2024 10:27am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I tried the Impergom valve when the factory one finally failed after 15 years.
The Impergom just behaved for a month and started leaking copiously from the back. Not impressed.
It is now replaced with a genuine Peugeot one (PSA ref 6448P6) and all is well again.
However I would be considering the IRB upgraded one if someone could confirm how progressive the heater control is with it compared to the genuine one which is more just on/off than anything else.
/Mat
Post #1049651 24th Oct 2024 1:54pm
Zed
My IRB heater control valve arrived last week. Sadly I haven’t had a chance to fit but it truly is a thing of beauty. It deserves to be hung in the Louvre not hidden under my bonnet!
Cheers Ian. WARNING.
Post #1052138 18th Nov 2024 9:51pm
Naks
^ I so wanted one for Xmas, but totally sold out. Rolling Eyes --
Post #1052165 19th Nov 2024 9:11am
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
IRB valve
Cheers Ian.
Agree far too beautiful to fit Laughing
However mine is in place and working beautifully, thank you Ian 'Porny' Bow down 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #1052194 19th Nov 2024 2:20pm
