![]() | Home > In Car Electronics > 130mm (5 inch) speakers in the rear |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
I have a feeling Mud U.K. do some solutions you might be looking for, I seem to remember they did. WeWillWin🇬🇧🇺🇸
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4260 ![]() ![]() ![]() |
They do, but I probably need to speak to them as it's not very clear on the website. I was hoping someone on here has trodden this path before. 2007 110 TDCi Station Wagon XS
I believe BarbelJim on here has in the locations you suggest, I’m not sure when he was last on here though.
I know what you mean regard listings with scant details, it’s a bit difficult to buy something without knowing exactly what it is. I seem to remember I saw the same ones on there as you have and thought the same that there wasn’t much info on them. Except for a basic picture and price. If I remember rightly it depends on the tub type, as a HT and SW rear tub is different, the SW has a step down which the plastics or fibreglass has to match. This is presuming the lower locations in the rear. You could take a look at La Salle too. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Mud do a replacement panel that takes 5" speakers but it's not suitable for a stepped tub. They suggest that their 5" speaker spacers can be used on the OE speaker panel, but it isn't clear how well they fit or if any trimming is still needed.
There also the Masai speaker housing that go up by the rood, but that then leaves me with 2 holes where the speakers originally were. 2007 110 TDCi Station Wagon XS |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 56 ![]() ![]() ![]() |
I have fitted 6in. speakers to the rear of mine. I dremelled out the inner step of the recess in the factory molding, drilled holes for the screws and it all fitted in nicely. Looks quite standard, works well, was quite simple to do. No spacers.
Sounds promising, you wouldn't happen to have a photo would you? 2007 110 TDCi Station Wagon XS
Not to hand, but stand by.
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1467 ![]() ![]() ![]() |
A few pics in this thread of panel mod and 5" speakers fitted.
Easy work with a dremel. https://www.defender2.net/forum/topic53232-15.html |
Yep, the post on the linked thread showing the panel trimming is pretty much what I did but through the whole aperture. The speakers I used were not as deep as some shown. That, of course, will make a difference to fitting. And probably sound quality. But it is a Deafener.
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1438 ![]() ![]() ![]() |
I’m still about but the puma is long gone. I trimmed the rear panel as shown in the link. It’s easy, just measure twice cut once ![]() And the homemade mdf boxes are still going well in the back of my td5 |
Good to see you on here Jim.
My install is almost complete, I only need one cable and a couple of bits to fully finish it. ![]() I have 4x 6.5” and 4x 4”, two Tweets up front plus sub. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
