Home > In Car Electronics > 130mm (5 inch) speakers in the rear
Bluest
What's needed to fit them neatly in the rear of a station wagon. Would prefer not to cut the speaker panel if possible. Can it be done with a Mud spacer ring? If not, how much trimming/ butchery is required? 2007 110 TDCi Station Wagon XS
Post #1047778 5th Oct 2024 4:39pm
I have a feeling Mud U.K. do some solutions you might be looking for, I seem to remember they did. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1047792 5th Oct 2024 6:17pm
Bluest
They do, but I probably need to speak to them as it's not very clear on the website. I was hoping someone on here has trodden this path before. 2007 110 TDCi Station Wagon XS
Post #1047796 5th Oct 2024 6:42pm
I believe BarbelJim on here has in the locations you suggest, Iโ€™m not sure when he was last on here though.
I know what you mean regard listings with scant details, itโ€™s a bit difficult to buy something without knowing exactly what it is. I seem to remember I saw the same ones on there as you have and thought the same that there wasnโ€™t much info on them.
Except for a basic picture and price.
If I remember rightly it depends on the tub type, as a HT and SW rear tub is different, the SW has a step down which the plastics or fibreglass has to match.
This is presuming the lower locations in the rear.
You could take a look at La Salle too. No Guts, No Glory.
Post #1047801 5th Oct 2024 6:46pm
Bluest
Mud do a replacement panel that takes 5" speakers but it's not suitable for a stepped tub. They suggest that their 5" speaker spacers can be used on the OE speaker panel, but it isn't clear how well they fit or if any trimming is still needed.
There also the Masai speaker housing that go up by the rood, but that then leaves me with 2 holes where the speakers originally were. 2007 110 TDCi Station Wagon XS
Post #1047803 5th Oct 2024 6:52pm
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
I have fitted 6in. speakers to the rear of mine. I dremelled out the inner step of the recess in the factory molding, drilled holes for the screws and it all fitted in nicely. Looks quite standard, works well, was quite simple to do. No spacers.
Post #1047820 5th Oct 2024 10:02pm
Bluest
Sounds promising, you wouldn't happen to have a photo would you? 2007 110 TDCi Station Wagon XS
Post #1047837 6th Oct 2024 7:45am
skidrov
Not to hand, but stand by.
Post #1047855 6th Oct 2024 10:22am
DSC-off
A few pics in this thread of panel mod and 5" speakers fitted.
Easy work with a dremel.
https://www.defender2.net/forum/topic53232-15.html
Post #1047858 6th Oct 2024 10:40am
skidrov
Yep, the post on the linked thread showing the panel trimming is pretty much what I did but through the whole aperture. The speakers I used were not as deep as some shown. That, of course, will make a difference to fitting. And probably sound quality. But it is a Deafener.
Post #1047861 6th Oct 2024 10:50am
barbel jim
Iโ€™m still about but the puma is long gone. I trimmed the rear panel as shown in the link. Itโ€™s easy, just measure twice cut once Thumbs Up
And the homemade mdf boxes are still going well in the back of my td5
Post #1047887 6th Oct 2024 3:17pm
Good to see you on here Jim.
My install is almost complete, I only need one cable and a couple of bits to fully finish it. Twisted Evil
I have 4x 6.5โ€ and 4x 4โ€, two Tweets up front plus sub. No Guts, No Glory.
Post #1047897 6th Oct 2024 4:20pm
