Home > Puma (Tdci) > Output shaft - updated genuine or Ashcroft?
Page 8 of 9 <123456789>
spudfan
Ireland
Our 2008 and 2011 are both on their origional shafts. The 2008 has over 200,000kms on it while the 2011 is coming up to 100,000kms. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #985371 13th Mar 2023 10:58am
nitram17
I really wonder what the true incidence of shaft failure is on pumas....... Because we inhabit lr forums are we just seeing a biased sample because of this?and do you represent the many thousands of puma owners who don't have shaft problems after 100.000 miles or so.
Post #985398 13th Mar 2023 12:57pm
It was bad enough for my local main dealer's friendly senior technician to tell me about the problem when I bought my Puma. In 2010 he told me that they'd replaced "a significant number" in three years. The only thing they'd had to replace more of was the VCV.
He also told me that they were investigating the feasibility of fitting a grease nipple to the coupling with an access hole in the housing. That a main dealer was thinking on those lines on a vehicle which had been in production for only three years at the time suggests that it was a significant problem even then.
Post #985412 13th Mar 2023 2:38pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Julie wrote:
Julie wrote:
Hi folks, any known issues with the Ashcroft shaft so far? I'm on Ashcroft for 2 years / 20000 km and no issues so far Thumbs Up
Hi - 3 yrs / 35 000 km - no issues Thumbs Up
Hi folks,
Unfortunately, I have to update my post :
the Ashcroft output shaft was good for 90 000 km. Last year it started leaking and now it looses so much oil - I changed the oil and it holds just the 1.5 to 1.6 pints below the spline
Neutral
It's the blue Ashcroft kit from 2018.
What solution should I go for ?
The original Land Rover spline did 60 000 km
The Ashcroft spline did 90 000 km
and I don't know if the upgraded Ashcroft kit is so much better ...
Post #1040473 20th Jul 2024 2:10pm
Dinnu
No affiliation with Ashcroft, but as I understand, you claim a fail because it started leaking? Splines still holding, but of unknown state of wear?
As I am aware, Ashcroft redesigned the cup to the red type. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1040483 20th Jul 2024 2:48pm
Julie
Yes, it started leaking and now it looses any oil above the level of the O-rings
It seems like the red Ashcroft kit is more a mechanical upgrade of the blue one, related to hardness and a tighter fit - that's what they say Down Under :
https://www.aulro.com/afvb/90-110-130-defe...ost2940846
If I compare photos, I see 2x 2 O-rings in the blue and the red kit :
blue : https://www.lrparts.net/lrc1517-mt82-gearb...sions.html
red : https://ashcroft-transmissions.co.uk/produ...gallery]/2
That's what I found out so far.
Now I'm wondering if the red Ashcroft kit really is an upgrade with respect to oil tightness ...
Post #1040489 20th Jul 2024 3:07pm
MK
Other 2 kits available in the market LOF and IRB. I have not heard how they perform. Puma 110" SW
Post #1040492 20th Jul 2024 3:25pm
Dinnu
Seems like the red cover uses thicker O rings on the shaft. Perhaps also to allow more movement between the cup and the shaft.
When I bought my Defender it had quite a bad leak, and found that whoever fitted the Ashcroft shaft, cross threaded the cup and compromised the sealing.
Btw, I do not think the gearbox oil level is that high. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1040499 20th Jul 2024 4:02pm
Julie
You have excellent eyes Thumbs Up
Indeed the "red" spline seems to have bigger O-rings on the shaft than the blue one.
The Germans even sell a replacement kit for these Ashcroft O-rings
https://www.nakatanenga.de/en/vehicle-equi...shaft-mt82
... so this seems to be a common issue ...
P.S. Yes, the oil level (and even the filler hole) seems to be below the spline
Post #1040502 20th Jul 2024 4:36pm
RobKeay
My transfer box was in for changing. So brought a new shaft for while we are in there. The mechanic, same one who fitted the first one is still trying to remove it. Says he has put seven hours into it now. He is now saying he is going to remove the back of the gearbox.
Does this sound right?
Post #1046537 23rd Sep 2024 7:41am
andy63
Not sure what you mean by removing the back of the gearbox..with the transfare box removed you would be best to remove the extension housing between transfare box and the gearbox output..that will give as good access to the output shaft cup as you can get...short of removing the gearbox as well..
Post #1046553 23rd Sep 2024 10:49am
Julie
You can see "the back of the gearbox" on the photograph I posted on July 20
IMO you do not intervene on the gearbox. but you have to reove the spline from it (which can be a bit sticky - as shown on the photograph).
There is a housing covering the spline (it has been removed and is not represented on the photo). You can see the holes for the bolts all around the gearbox.
I had this done by an independent garage specialized on the Defender.
I booked the truck in @ 10 am and I took it @3 pm. So the work can be accomplished within 5 hours.
Post #1046566 23rd Sep 2024 12:34pm
RobKeay
That’s what they have done now. Not sure what they were trying to do before. I think when we changed last time the original one just fell out because it was kanckered.
All sorted now hopefully back on the road tomorrow. 👍
Post #1046602 23rd Sep 2024 6:13pm
Randlover
 2010 Defender 90 Puma 2.4 XS CSW Galway Green
I'm now on 108k on original output shaft, it must've been greased at least a little on build as that's decent mileage to achieve from what I understand?!
I am having it replaced next week along with the a frame ball joint (torn rubber boot)
I have always had some transmission clunk at the rear somewhere (sounds like rear) diff oils changed with no scray metallic dirt in, half shafts replaced for LOF one piece & front flanges replaced for new and made no difference to the noise.
I bought it from the original owner about 3k miles ago
Absolutely love the thing just hope the a frame joint & output shaft replacement settle the clunks a bit
Post #1047143 28th Sep 2024 11:39pm
BrickBox
Clunks are just part of the character of a Defender. But I have a LOF one piece output shaft and it significantly reduced the clunks.
With the posts of leaking Ashcroft shafts, I’m glad I went for the 1 piece LOF fit and forget..(so far) 2008 2.4 110 Utility Station Wagon XS.
Post #1047153 29th Sep 2024 5:34am
