Home > In Car Electronics (L663) > Rear Windows Activation 110 Hard Top
Page 3 of 3 <123
mattlidster
United Kingdom 1989 Defender 90 300 Tdi ST Alpine White
Did you have any luck with the rear door puddle lights? The new loom I fitted has the wires there but they dont come on. I have even tried leaving the 2 that did work as a commercial but adding 2 new lights to the doors but still no luck. I cant see anything obvious in the CCF that could be changed.
Post #1019515 29th Dec 2023 11:42am
Paladino
Hi, unfortunately it's not coding related - the positive wire for the puddle light that goes from the bcm to the door connector is missing on commercial vehicles.
Post #1019583 30th Dec 2023 12:18am
mattlidster
Ah ok, does that mean you cant get the ambient LED lights to work either with this additional loom LR130014?
Post #1019603 30th Dec 2023 9:12am
Paladino
Yep. You will need additional wiring. For the ambient leds - lin comes from the door module, earth is also in the door i believe, but the power comes from the bcm.
Post #1019608 30th Dec 2023 9:49am
Ducatirider2024
L663 Window conversion
I am looking at starting my own project on my L663 2024 and have a couple of questions if ok
Did you install the door close handle and new panel or just cut the panel to take the switch
How do I do the config
Did you use a disco switch in the front in the end and if so what year did you go for
Also fancy putting two single seats in the rear with hot and cold do you think this is possible from what you did when you installed yours and how dod you get the heat and cold work on your seats
Appreciate any guidance thank you paul
mattlidster wrote:
Mine is a 2022
Removed both rear door wiring looms completely.
Parts used so far
New wiring loom Drivers side rear door LR171801
New wiring loom Passenger side rear door LR171817 ( I think that's the right way round!)
2 X new switches LR059773
2 X new switch facias LR064090
New door Moulding round small window LR149591
New door Moulding round small window LR149592
New front door window switch with mirrors and memory seats LR130144
Changed Car Config File via IIDTool
MultiCAN-634 MovingWindows
Four Moving Windows
EUCD-109 Power Windows, Front/Rear
DCU Powered Front & Rear Windows
Post #1046073 18th Sep 2024 9:16am
Page 3 of 3 <123
