![]() | Home > In Car Electronics (L663) > Rear Windows Activation 110 Hard Top |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 ![]() |
Hi, unfortunately it's not coding related - the positive wire for the puddle light that goes from the bcm to the door connector is missing on commercial vehicles.
mattlidster Member Since: 17 Jan 2017 Location: UK Posts: 17 ![]() ![]() ![]() |
Ah ok, does that mean you cant get the ambient LED lights to work either with this additional loom LR130014?
Yep. You will need additional wiring. For the ambient leds - lin comes from the door module, earth is also in the door i believe, but the power comes from the bcm.
Ducatirider2024 Member Since: 18 Sep 2024 Location: Bolton Posts: 1 ![]() ![]() |
I am looking at starting my own project on my L663 2024 and have a couple of questions if ok
Did you install the door close handle and new panel or just cut the panel to take the switch How do I do the config Did you use a disco switch in the front in the end and if so what year did you go for Also fancy putting two single seats in the rear with hot and cold do you think this is possible from what you did when you installed yours and how dod you get the heat and cold work on your seats Appreciate any guidance thank you paul
