Home > Puma (Tdci) > Clutches - Sachs Transit 4x4, LOF, Clutchfix etc.
Page 3 of 3 <123
Bluest
First drive with Transit clutch. Feels much the same as the stock one did but no rattle for now. Pedal might be a touch heavier, but it's hard to say as ive been driving my daily hatchback with super light clutch for that 2 weeks. 2007 110 TDCi Station Wagon XS
Post #1041703 2nd Aug 2024 8:22pm
Sounds like mine and that’s good. Thumbs Up
One of the things I notice now I’ve driven it a few months and few thousand miles is less slip than the Genuine version I think it handles the torque better and Pumas have quite high torque.
I’m hoping the springs will last better than LR too, on the last LR clutch I had a sling came out causing almost total failure, and the one before that was the earlier 2.4 slave that failed but was told the springs were very very loose.
On none of them, did they have the friction plate worn heavily but instead other failiures. NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #1041714 2nd Aug 2024 9:52pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Bluest wrote:
Mine has rattled for as long as Ive owned it, standard OE clutch. I've had a couple of people tell me the rattling is not always the clutch. It can be from the gearbox. Don't know how true it is, but they were both mechanics that said it.
It can be, but the most common culprit is the centre of the clutch being slightly loose, and clattering at idle when everything is hot. Usually the springs being loose. The different rattles can of course encourage each other - i.e. a bit of play in a less than perfect clutch centre might set up oscillations in the gearbox as well. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #1041748 3rd Aug 2024 10:19am
ickle
The time will son come to do the clutch again on my 2.4, when I did it originally I swapped to the later 2.2 release bearing.
I going down the Transit clutch route, as the OEM, Borg & Beck x2, were poor, Clutch Fix has been OK but is now jerky and rattly.
I will fit a new release bearing/cylinder but is there a need to change the adapter & valve as well?
Cheers Keith
Post #1045528 11th Sep 2024 11:27am
andy63
Not sure about the this but I did notice when I replaced my clutch with a kit from lof that it came complete with the fittings that attach the slave to the bleed and then the little valve/adapter to connect to the hose fitting.. whilst the adapter may not have needed changing the internal bell housing fitting was a different .ie length to the connector.. I'm not sure if the slave release bearings come with their own connecting pipe..but the old and new on mine were not interchangeable, from memory anyway..
Post #1045532 11th Sep 2024 12:20pm
MK
Cheers Keith
To be on the safe side I would only change the O´rings. Puma 110" SW
Post #1045534 11th Sep 2024 12:26pm
ickle
Thank you MK - thats a good idea.
Keith
Post #1045583 11th Sep 2024 7:25pm
If you fit a later 2.2 slave on a 2.4, then you’ll need the later 2.2 valve and adaptor too.
That’s what I did, if you do have a 2.2 I would still go for new parts, these parts are not a job you want to go back over to do for obvious reasons. NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #1045584 11th Sep 2024 7:39pm
BrickBox
I think the LOF clutch bundle is a perfect kit for everything you need. 2008 2.4 110 Utility Station Wagon XS.
Post #1045589 11th Sep 2024 8:41pm
Page 3 of 3 <123
