Home > Td5 > Thoughts on TD5 Fuel Mileage |
CJs110 Member Since: 06 Sep 2023 Location: Windsor Posts: 20 |
Sorry for the delay.
No black smoke at all not even under hard acceleration. Only on cold starts there is a puff of smoke - not black but grey kind of like unburnt fuel smell? Not sure if it has a tune on it, but I doubt it, its pretty slow tops out at maybe 78-80mph in 5th and it definetly takes its time to get to 60. I do notice that the EGR is deleted. Luckily the fuel gauge does move so I can mostly trust it. Plus I am measuring MPG at the pump. Any other thoughts where/what to look for? |
7th Sep 2024 1:24am |
Bluejohnone Member Since: 20 Aug 2021 Location: Stalybridge Posts: 7 |
I have a 2001 Td5 90, with FSH and 130K miles.
I don't have any problem getting 30mpg+ (UK mpg) if you drive as they were designed. I find the sweet spot 60 to 65 mph. US mpg will be c20% less with all things being equal. #1 Series 2A #2 1999 TD5 #3 2001 TD5 (current) |
7th Sep 2024 3:51am |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 509 |
I’ve no experience with Td5 mpg but from your text it seems that your driving pretty much flat out, moderately loaded, so I’d be expecting mpg to be at the lower end of the scale.
I used to ride a motor bike and on a long trip to the south of France on their autoroute I was only getting 38 mpg, but was travelling at a continuous 75-80 mph - quite high for the machine. If I dropped my speed to 60-65 the economy would increase to around 62mpg, which was what was normal and much more comfortable, if a bit more boring. My 110 auto does 20 generally but I’ve had 27 on a uk motorway, driven at its comfortable limit of around 60-65, not it’s actual limit of at least 90 ( it’s a non standard engine ) On another trip to France with our 3.2 litre car, we had an average of 31 mpg, that included plenty of high speed, but cruising at 80 mph on the autoroute. Back home it gets 25 mpg, but I’d expect to achieve 34 -36 mpg at a constant 65 on the autoroute, although that would be extremely dull and a waste of a rapid car! |
7th Sep 2024 8:26am |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 205 |
Hello,
My 110 (stage 1 remap and Disco2 Transfer box) with wife, dog, me and camping gear did 1100 mixed miles @ 34 mpg (UK). That was mainly in the 60 - 70 mph range but with plenty of trips into the 70 - 80 range... Have you checked how well your Landy freewheels..?? Have you got access to a laser thermometer to check/compare the heat of your disks after a drive..?? Hope you get it sorted. Dave. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
7th Sep 2024 8:59am |
I will definitely do a test to see how well it freewheels.
While I agree cruising at higher speeds could be my loss in MPG I do want to make sure everything else i in good shape. I have gone ahead and ordered a Nanocom. Based on what I have read on the forums for these TD5's it is an important tool to be able to see if everything is functioning as it should. Plus Evil Elsie - your setup Stage 1 + Disco 2 TB is what I have been looking into. Once I can confirm everything is working as it should I will look into Stage 1 remaps - my Defender has a EGR delete but stock intercooler/stock replacement air filter/stock exhaust Question which Stage 1 did you purchase? And anything to look out for when looking for a Disco 2 TB? I see a 2000 V8 being parted out. |
21st Sep 2024 5:19pm |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 164 |
If you are running the standard transfer box ratio 55-60 mph is probably the best speed.
Even with a the 1.2 ratio 55-60 is a happy speed and should return approx 30 mpg UK. I would suggest you consider a different transfer box ratio or a Roamer drive overdrive if you intend to do long journeys and want to reduce your fuel consumption. |
23rd Sep 2024 7:46am |
Hello CJ - sorry for late reply....
Mine has an 'Alive' stage 1 remap - I can't recommend it enough, an absolute game changer..!! Standard turbo and intercooler but the turbo boost dialled up to 1.2 bar (set on my Nanocom). She gets up to 70mph quickly considering size/weight/aerodynamics 😀 I also add 2 stroke oil to my fuel @ 250:1 ratio. I'm positive that this helps... 1100 miles - mainly fast roads but a few traffic jams and some town/city driving returned 34.3 mpg (UK) = 28.5 mpg (US). 265/75 All Terrain tyres @ 33 psi. EGR deleted. 175k miles. Cheers, Dave 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C Last edited by Evil Elsie on 25th Sep 2024 9:56am. Edited 1 time in total |
24th Sep 2024 4:23pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
I normally only use my td5 110 to tow a small 14’ aluminum boat to the cabin and back over the weekends. ( need the defender specifically to wade in 24” of water to launch the boat off of a beach)
Approx 400kms round trip doing between 110-115kph and get right around 10-10.5 liters/100km. Truck normally loaded with wife, dog and gear and normally 50-100kg of construction supplies tied inside boat.ODO 170k km, R380, standard 1.4 TC, no tune, new GY Wranglers. ( owned for 9 years since 2015 and 96k km) Recently deleted EGR and find it marginally more responsive and a better top end on the highway while towing ( less need to downshift to 4th on long hills on highway) Your mileage may vary….? Patrick |
24th Sep 2024 7:34pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 956 |
Patrick, are you a member of Ottawa Valley Land Rovers? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
25th Sep 2024 7:07pm |
Yep…member 343. I was hoping to attend last weekends event, unfortunately, I had a prior commitment and wasn’t able to go.
My closest friend was the one with the light blue 110 that that turned his track rod into an x² function on the trail…..twice. Patrick |
25th Sep 2024 8:55pm |
Ahhh yes you are that Patrick!!!
Showing off your club stickers and making him jealous😆😆 See you out at the next event (hopefully). Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
25th Sep 2024 9:15pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2227 |
I got 430 miles from my 5 cylinder 5 gears TD5
But now get 330 miles from my 4 cylinder 6 gears TDCi 😮 |
26th Sep 2024 11:33am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2932 |
If you haven't done so recently, change the MAF unit. lf that fails you won't know (no warning lights and it still runs fine)
But the ECU defaults to a preset map and MPG drops 10-20%. Also l would agree with the above. 70mph is too fast, at 60 mph my TD5 110 did 25mpg. (UK gallons) At 70mph the engine was turning at 3,000 rpm and economy dropped to 20mpg At a steady 50mph during a Spanish road trip l managed 32mpg So it's all about the speed. And check your MAF unit. There's no real test for a faulty MAF. Some say you can disconnect it and see if the engine runs any different. But that never had any discernible effect on mine, even with a new genuine LR MAF unit fitted. |
27th Sep 2024 6:30pm |
Thanks all for the replies.
Some really good insight. I will defineitly check the MAF - I was actually reading about a diagnosis process on Empires site. Waiting for that Nanocom to come in - status says it has shipped. Hoping to have some info to post shortly. In the meantime agreed about speed v mileage compelety, though I still believe I should be getting (slightly better). My reasoning for the Disco Tcase and Stage 1 is more so for driveability, but would be nice if I end up doing longer highway drives. I was looking at Alive's site and unfortunatly it looks like they currently do not support tuning through Nanocom due to Nanocoms latest update..... Ideally would like to not purchase yet another piece of hardware. So we shall see. Stay tuned!! |
27th Sep 2024 7:12pm |
