Home > Td5 > Thoughts on TD5 Fuel Mileage |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
CJ
Not that you are close by but if you do find your way to somewhere near Ottawa, I do have a Nanocom you can borrow. They are super slick and when I used to drive the Defender back and forth from Ottawa to Halifax, I used to leave it installed all the time to monitor parameters. Well worth the investment for someone in Canada , far from TD5 SMEs. Patrick |
27th Sep 2024 11:05pm |
CJs110 Member Since: 06 Sep 2023 Location: Windsor Posts: 20 |
Patrick, thank you for the offer much appreciated.
My unit just got delievered! So I will be messing with it over the next bit and keep an eye on the inputs (i'm thinking maf, map, aat, etc) while driving to see if theres anything off. Agreed Lightning that the speed is likely = high rpms. Now with the Nanocom I can see just how high! Stay tuned! |
11th Oct 2024 5:18pm |
