Home > Maintenance & Modifications > Inside seat box sound deadening
excossack
Just wondering what people use to line the inside of the seat boxes to reduce noise / heat transfer? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1042073 6th Aug 2024 4:41pm
landy andy
Dynamat on previous models. Now I donโ€™t bother. Itโ€™s a Defender.
Post #1042076 6th Aug 2024 5:18pm
Dynamat on the interior base panel, 2mm adhesive foam (generic) on a bit of the internal vertical sides.
Dynamat over the seatbox external areas. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1042084 6th Aug 2024 6:38pm
Lightwater
Australia
There maybe some ideas here, I actually was looking at Defenders for ideas.
https://www.freel2.com/forum/topic33026.html Visitor - Freelander owner
Post #1042100 7th Aug 2024 6:09am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Dynamat and then Dodo Thermo Liner Pro 5mm SE inside and outside the seatbox and gearbox tunnel where I could made big difference to the heat.
Post #1042109 7th Aug 2024 9:27am
excossack
Thanks all. I figure any noise & head reduction has to be a good thing Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1042110 7th Aug 2024 9:29am
excossack
To the untrained eye, there appears to be products from manufactures that do the same thing?
Sound Deadening Dodo Mat
https://www.ebay.co.uk/itm/165726189109
DYNAMAT Sound Proof Deadening
https://www.ebay.co.uk/itm/192642860395
Or
https://www.businessmindltd.co.uk/view-pro...0emI_uiqAE 1999 Defender TD5 110
Regards
John M0VAZ
Post #1042121 7th Aug 2024 1:26pm
Lightwater
Australia
My experience on the Freelander, even though it is a quiet car to start with. Is don't go overboard with butyl. it is simply to stop nodal points resonating.
Fill any & all areas as much as possible with acoustic foam. Including stuffing down A, B, C & D pillars.
The ceiling in my Freelander has 35 - 45mm of foam. Have filled all spaces possible around the car.
My gut feel, 25mm on every reasonably possible surface. 50mm where you can is the go. If you can go thicker all the better. The thicker the foam the lower frequencies it will subdue.
I also looked at hi-fi base dampers. Often they use unpacked ceiling batts in the original compressed packaging. Higher density, but not too much, in corners of rooms.
50mm thickness of foam on average around the car is the starting point. 2, 5 or 10mm is a waste of time on average. Median thickness around the car needs to be 50mm at least.
Do your ceiling, I was surprised just how much difference it made on the Freelander. Visitor - Freelander owner
Post #1042176 8th Aug 2024 2:07am
excossack
Thanks Lightwater. Certainly food for thought...or sound deadening for thought.... Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1042720 14th Aug 2024 8:02am
