Home > Maintenance & Modifications > Inside seat box sound deadening |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
Dynamat on previous models. Now I donโt bother. Itโs a Defender.
Click image to enlarge |
6th Aug 2024 5:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20430 |
Dynamat on the interior base panel, 2mm adhesive foam (generic) on a bit of the internal vertical sides.
Dynamat over the seatbox external areas. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
6th Aug 2024 6:38pm |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 72 |
There maybe some ideas here, I actually was looking at Defenders for ideas.
https://www.freel2.com/forum/topic33026.html Visitor - Freelander owner |
7th Aug 2024 6:09am |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Dynamat and then Dodo Thermo Liner Pro 5mm SE inside and outside the seatbox and gearbox tunnel where I could made big difference to the heat.
7th Aug 2024 9:27am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Thanks all. I figure any noise & head reduction has to be a good thing 1999 Defender TD5 110
7th Aug 2024 9:29am |
To the untrained eye, there appears to be products from manufactures that do the same thing?
Sound Deadening Dodo Mat https://www.ebay.co.uk/itm/165726189109 DYNAMAT Sound Proof Deadening https://www.ebay.co.uk/itm/192642860395 Or https://www.businessmindltd.co.uk/view-pro...0emI_uiqAE 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
7th Aug 2024 1:26pm |
My experience on the Freelander, even though it is a quiet car to start with. Is don't go overboard with butyl. it is simply to stop nodal points resonating.
Fill any & all areas as much as possible with acoustic foam. Including stuffing down A, B, C & D pillars. The ceiling in my Freelander has 35 - 45mm of foam. Have filled all spaces possible around the car. My gut feel, 25mm on every reasonably possible surface. 50mm where you can is the go. If you can go thicker all the better. The thicker the foam the lower frequencies it will subdue. I also looked at hi-fi base dampers. Often they use unpacked ceiling batts in the original compressed packaging. Higher density, but not too much, in corners of rooms. 50mm thickness of foam on average around the car is the starting point. 2, 5 or 10mm is a waste of time on average. Median thickness around the car needs to be 50mm at least. Do your ceiling, I was surprised just how much difference it made on the Freelander. Visitor - Freelander owner |
8th Aug 2024 2:07am |
Thanks Lightwater. Certainly food for thought...or sound deadening for thought.... 1999 Defender TD5 110
14th Aug 2024 8:02am |
