Home > My Defender > Neglected for too long |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5221 |
i have a few jobs that i was hoping to start on mine, but a 1900 quid bill has put the stop to that, sadly, I am wanting to do a door card change on mine,
What seats are those? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
11th Aug 2024 11:32pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 600 |
Seats are from an Evoque, very comfy, look good, electrics a nice touch but they are very high so not for everyone.
Still need to track down 4 of these screws... Click image to enlarge Click image to enlarge Also popped the new fridge in the back... Click image to enlarge |
12th Aug 2024 3:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
โStill need to track down 4 of these screws...โ
Any help?: https://www.lrworkshop.com/diagrams/land-r...acia_45040 KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
12th Aug 2024 3:38pm |
That's great, thanks. ยฃ4 a screw??? there's a joke in there somewhere
14th Aug 2024 12:18am |
This is LR you are talking about, you pay for the packet, packaging and logo not the produce / product.
14th Aug 2024 12:00pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10853 |
What a cracking track playing in pic 10, from the top down Clayton.
16th Aug 2024 7:54pm |
Isn't it just... actually had set it as the alarm on my phone to remind me to to give an old safe i am restoring a second coat ....
18th Aug 2024 10:16pm |
Clayton.
19th Aug 2024 8:00pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 744 |
The Front seats look nice, but how do you gain access to the batteries, relays, and fuses in the seat box? No Better Friend, No Worse Enemy
24th Aug 2024 3:27am |
Hi,
Its just 4 bolts, takes 2min. Not as convenient as a pull out base but in reality I have "HAD" to get the under seat area twice in about 8 years. A set of Anderson connectors would solve both those instances just never bothered. |
27th Aug 2024 10:54pm |
Hi,
The dust caps you can get for Anderson connectors are good, they might not be quite IP68 waterproofing, but enough to be very resilient to general dust and wet.
I have a couple of them in a 50/50 exposed area to the elements and they have been trouble free since installation, they are great to disconnect from for say front mounted lights as they can carry very good current but also easy to disconnect. Even the pins are tinned inside so have very good longevity possibilities and less voltage drop for higher current applications. So much better than say pre insulated spade connectors taped up, and Superseals are good but very limited to their current capacity, even uprated ones still are relatively low. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช Last edited by custom90 on 28th Aug 2024 11:52am. Edited 1 time in total |
28th Aug 2024 8:27am |
Stiff1 - Have you considered a Naka DAB Aerial? I think that would look nice on yours. KEEP CALM AND Drill ON
28th Aug 2024 8:28am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17538 |
AMP Superseal connectors are rated at 14A continuous per contact, which isn't particularly low. You would be ill-advised to plug/unplug them under load (especially with a DC load) but there are relatively few electrical items on most classic Defenders which use more than 168W. |
28th Aug 2024 8:52am |
